SHTC3 Temp and Humidity data is not getting passed to Blynk data
I have written the some sample code, I know I have a connection to Blynk dashboard, I know my SHTC3 read, and print is working (I also know the code is working as extracted from an INflux DB example program i wrote).
However when I pass this to the Blynk write function
Blynk.virtualWrite(V0, temperature); // Virtual pin V0 for temperature
Blynk.virtualWrite(V1, humidity.relative_humidity); // Virtual pin V1 for humidity
I do not see the values for temperature and Humidty. all I get is 1 (Which is what I see coming through on the blynk dashboard.) I also proved this by printing to the serial port the value of V0 and V1 both come back as 1.
I am guessing there is a configuration issue? or is there a different blynk function?
ESP32, Code written under VSCODE platformIO.
I doubt its any version issue?
Read this before creating new topic:
#define BLYNK_TEMPLATE_ID "TMPL5sgXXht3-"
#define BLYNK_TEMPLATE_NAME "RH"
#define BLYNK_AUTH_TOKEN "SQJ5kFVM1VbWPAaW8IYGxcFTsPjJE0oJ"
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_SHTC3.h>
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
float temperature;
float humidity;
float humidityValue;
#define BLYNK_FIRMWARE_VERSION  "0.1.0"
// SHTC3 sensor instance
Adafruit_SHTC3 shtc3 = Adafruit_SHTC3();
// Blynk credentials
//char auth[] = "SQJ5kFVM1VbWPAaW8IYGxcFTsPjJE0oJ";  // Replace with your Blynk auth token
char ssid[] = "Heybroadband3";         // Replace with your WiFi SSID
char pass[] = "123123123";     // Replace with your WiFi password
Adafruit_SHTC3 gSHTC3Sensor;
bool setupSHTC3Sensor() {
    if (!gSHTC3Sensor.begin()) {
        Serial.println("SHTC3.begin() failed1st");
        return false;
    return true;
  // Initialize Serial Monitor
  while (!Serial)
    delay(10);     // will pause Zero, Leonardo, etc until serial console opens
  // Initialize Blynk
  //Blynk.begin(auth, ssid, pass);
  // Initialize I2C and SHTC3 sensor
  Wire.begin();
// Initialize SHTC3 sensor
  if (!setupSHTC3Sensor()) {
    Serial.println("Couldn't find SHTC3 sensor");
    return;
    Serial.println("Found SHTC3 sensor");
  sensors_event_t humidity, temp;
  //shtc3.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
//sensors_event_t humidity, temp;
  if (gSHTC3Sensor.getEvent( &humidity, &temp)) {
    // successful read, do something with the values:
    Serial.print("Temp:"); Serial.print(temp.temperature); Serial.println(" degrees C");
    Serial.print(" RH:"); Serial.print(humidity.relative_humidity); Serial.println("% rH");
  temperature = temp.temperature;
  humidityValue = humidity.relative_humidity;
  // Print temperature and humidity to the Serial Monitor
  Serial.print("Temperature: "); Serial.print(temp.temperature); Serial.println(" °C");
  Serial.print("Humidity: "); Serial.print(humidity.relative_humidity); Serial.println(" %");
 //Start Blynk run loop
  // Send temperature and humidity to Blynk virtual pins
  Serial.print("blynk V0  " ); Serial.print(V0);
  Serial.print("  Blynk V1  "); Serial.print(V1);
  // Wait for 2 seconds before the next reading
  delay(2000);
First of all, you should read this…
Can you explain exactly how you did this?
I’m curious about why you’re doing this…
then not using these temperature and humidityValue variab;les, except here…
How are your V0 and V1 datastreams defined, especially their min/max values ?
I actually used codes from several GIthub/Web tutorials on the net, all of which appear to be actually wrong - So I just found. In fact if I drop the V from V0, and V1, it magically starts to pass through the data correctly!!
I took a quick look at the implementation of virtualWrite thereafter, and i see it looks for a pin index number
Anyway, appears to be solved now (although I intend to now do further testing).
