I have been trying to display distance measurements using the widget Gauge but I don’t know why it won’t work. Here are the codes I used
#define BLYNK_PRINT SwSerial
char auth[] = "...";
const int trigPin = 12;
const int echoPin = 13;
const int Buzzer = 6;
const int ledPin= 8;
int duration, distance;
int saveDis = 0;
int sound = 50;
int sensorData = 12;
void sendSensor (void) {
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
saveDis = distance;
distance = (duration/2) / 29.1;
Serial.println("Distance: " + String(distance) + "cm");
if (distance >= 300 || distance <= 0)
Serial.println("no object detected");
digitalWrite(Buzzer,LOW);
digitalWrite(ledPin,LOW);
noTone (Buzzer);
else {
Serial.println("object detected \n");
Serial.print("distance= ");
Serial.print(distance);
tone(Buzzer,400);
digitalWrite(ledPin,HIGH);
Blynk.notify("Distance: " + String(saveDis) + "cm to " + String(distance) + "cm!");
if (isnan(distance)){
Serial.println("Failed to read from ultrasonic sensor!");
return;
if(distance<300) {
Blynk.notify(String("DISTANCE:") + distance);
Blynk.virtualWrite(V0,distance);
delay (5);
BLYNK_READ(V0)
void myTimerEvent(void)
sensorData = digitalRead(13);
Blynk.virtualWrite(V0, sensorData);
void setup(void){
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(Buzzer, OUTPUT);
pinMode(ledPin, OUTPUT);
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
void loop(void) {
sendSensor();
