I’m in South Africa - and internet access quality varies from incredible to almost useless
Please give more visibility if a unit is connected or not.
At the moment the Android app shows at times a notice for a short duration at the bottom of the screen - but this is in my case not enough
Nico
@nvddussen
Hey Nico, yeap we aware of that issue. We plan to provide regional servers soon. But until that you may try local Blynk server.
Hi Dimitry,
thanks for the response.
A regional server will in my case not solve the problem
The problem is a “last mile” issue. Eg the local Telco can’t provide me with stable ADSL faster than 512kb/s upload and 2MB/s down. Even then, quite often ping losses exceeds 50%.
My suggestion: Please provide a “widget” in the Android app that I can use to show connection status very visible
Regards
Nico
PS: Connecting from a ESP8266 - first steps only
@nvddussen
In that case you could use a LED and this sketch. Idea is next - every X seconds send an ON and OFF command to a LED with small interval so you will see visually if all is ok (if LED in APP is Blinking).
Colud you resend one more time the mentioned sketch? its seems githup is no longer shown your link… thanks in advance…
