Shared timer (widget) doesn't work
Hi ,
I’m having issues with timers, they work when I program them with my “main” account, when I try to share my project with another device (without entering with the same account, just sharing the project with QR code), it is impossible to set timers. At the beginning it seems that everything is ok then after some seconds all timers reset .
I didn’t post the code because I work directly on hardware pin status.
I also used buttons and with them it works perfectly.
Anyone can help me?
• Hardware model Arduino MEGA with Ethernet Shield
• iOS iPhone
• Blynk server
I suspect this goes for adjusting Timer Widgets as well…
PS - https://community.blynk.cc/search?q=sharing%20timer%20widget
No sense :frowning:
I agree this makes no sense. It is good to not be able to change the fundamental GUI but in the case of timers, these are explicitly intended to be user functions so if I share the app and they can’t set their timers then it has no use. This is a fundamental purpose for sharing… is there any chance that this can be fixed? Otherwise I have to go back to doing it as my own web server and ditch Blynk.
@Timmalia are you on Android? This seems to have been already fixed on iOS.
I built a thermostat for friends and installed it yesterday. He has iPhone she has Android. Same issue on both platforms. They can change the timer and the GUI appears changed but then it suddenly changes back.
This was 21 Feb 21.
