Shared Access turned off by itself
Dear @Dmitriy
Yesterday I turned on Shared Access to one of my projects and I send also email with the QR CODE and link. Without switching off the Shared Access, today I found it off. When I tried to switch on, a new message (the normal) informs me for the 1000 energy units that I will consume if I continue… BUT I did already yesterday! Please consult what to do. In case you need, I can sent you the original email with the Shared Access details.
Thanks and Best Regards,
Mike Kranidis
I can confirm that this is a problem. It’s happened to me twice with sharing of the same project with my wife. Each time I had to re-share at a cost of 1000 energy units. I have now given up sharing and just gave her my login on her Blynk app (which is scary :thumbsdown:)
Is there no way to put a flag on the system that once a project has been shared and paid for, that it then remains shared.
Alternatively, another feature would be to be able to create a standalone apk of a project that can then be installed/sideloaded - of course, doing this means that any changes to the sketch would not update the app but it would work really well for sketches that are not likely to change.
Do you stop project or logout? If so this is correct.
Yes, I stoppet to change the behavior for one switch (from push to switch) and then I started again.
So, what happens, in this case I need another 1000 to re-shared again? After started, shows the sharing access turned off. Please explain.
Mike Kranidis
No. Do you use latest Blynk app? What exactly message do you see in shared app?
Dear @Dmitriy yes I use the latest Blynk App that Google Store have ( 1.15.2 ).
To express better the possible problem, see the attached photos and consult me accordingly…
Dear @Dmitriy DId you have any chance to see me problem above?
Please comment.
Thanks a lot
Yes. Issue is clear. We’ll check. Thank you for reporting.
OK thanks. Please let me know when its done !
Dear @Dmitriy,
regarding the reported problem, do you know when will be solved?
I need to share a project of mine and I can not! (I don’t want to re share it and to risk to loose 1000 energy units for nothing. If you check I have paid quite a lot to get energy and to support you.)
Please quide me accordingly.
Mike Kranidis
At Monday we will release new update with possible fix.
Dear @Dmitriy
I just put the new Blynk Android app but the Sharing button it is still at off. I think that if I slide it to on, then it will produce new sharing number etc and it will deduct 1000 energy units from my account. What do oyu suggest?
Thanks and Best Regards.
Mike Kranidis
Please tell me your acc name I’ll give you some free energy, After enabling sharing should work. If not - please tell us.
My account login name is: mikekgr
Do you need the email address?
email
xxxx@openforall.com
Done.
Thanks a lot @Dmitriy
