Here is my code - I have read for days but just cannot make a break through.
In addition I have a vibration sensor hooked up to D4, it reads 1 or 0. How do I activate the timer to push D4 to the app.
I have a delay in the loop but not sure if i should take it out.
An help is appreciated.
http://twitter.com/blynk_app
Output any data on LCD widget!
App project setup:
LCD widget, switch to ADVANCED mode, select pin V1
#define TRIGGERPIN D1
#define ECHOPIN D2
char auth[] = "c48e77b790e64b05adf1ee77fb4dbb40";
char ssid[] = "Bootload Error";
char pass[] = "theraininspain";
WidgetLCD lcd(V1);
void myTimerEvent()
Blynk.virtualWrite(V5, millis() / 3000); //was 1000
pinMode(TRIGGERPIN, OUTPUT);
pinMode(ECHOPIN, INPUT);
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(0, 0, "Distance in cm"); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
// Please use timed events when LCD printintg in void loop to avoid sending too many commands
// It will cause a FLOOD Error, and connection will be dropped
lcd.clear();
lcd.print(0, 0, "Sump depth in cm"); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
long duration, distance;
digitalWrite(TRIGGERPIN, LOW);
delayMicroseconds(3);
digitalWrite(TRIGGERPIN, HIGH);
delayMicroseconds(10); //was12
duration = pulseIn(ECHOPIN, HIGH);
distance = 68-(duration/2) / 29.1;
Serial.print(distance);
Serial.println("Cm");
lcd.print(7, 1, distance);
delay(1500); //was 3500
