Hello. Thank you for answer.
Ok, if dont use docker, server start and i can connect from mobile app Blynk, but i cant use web interface . Link myLocalIP:9443/admin dont working
This in rpi
I try install blynk server on mobile, in linux console. Server on mobile working!
Maybe need on rpi open ports? But i dont know how do it.
If you’re not using Docker and your device is connected to the same network as the Blynk server then you don’t need to open any ports.
What browser are you using, and what do you see when you try to access the admin portal?
Are you using https or http when you do this?
I use static ip from my internet provider.
You can see this page, its my server. http://95.52..:9443/admin
I use chrome on mobile, on home PCs and standart browser chronium on RPi . All browsers show one page with code:
ERR_CONNECTION_REFUSED
My mobile device is connected now with this ip and port 9443. But admin portal not working
Your very brave, posting your public static IP on a public forum!
You need to use https when connecting to the admin portal.
Are you using 95.xxx.xxx.xxx and port 9443 in the custom settings of the Blynk app, and is this working?
Thank you for try help me!
I fixed problem.
Web portal not working because i dont write line in server.properties:
allowed.administrator.ips=192.168..
Early writed address is 127.0.0.1 (localhost) and he not worked from local machine
