Hi, Im currently deveping a project to control 100 WS812B RGB Led using Blynk IOT. currently, im using free plan and limited to only 50 datastreams. To control all 100 leds individually, Im using a slider and 10 virtual pins.
project principle:
when slider == 1, V0 = 1, V2 = 2, …, V9 = 10
when slider == 2, V0 = 11, V2 =12, …, V9 = 10
Screenshot:
So, everytime slider changes value, the onLabels and offLabel of every virtual pin need to change. right now im using for loop to call Blynk.setProperty(V0, “onLabel”, “”); but it is slow updating the on and off labels.
sample codes:
#include <FastLED.h>
#define BUT_FREE 0
#define BUT_PRESSED 1
#define BUT_LOCKED 2
#define LED_PIN 14
#define COLOR_ORDER GRB
#define CHIPSET WS2812
#define NUM_LEDS 100
#define BLYNK_DARK_BLUE "#5F7CD8"
#define BLYNK_RED "#D3435C"
#define BLYNK_GREEN "#23C48E"
//LED VIRTUAL PIN TAB 2
#define VIRT_BUT_TAB2_0 V0
#define VIRT_BUT_TAB2_1 V1
#define VIRT_BUT_TAB2_2 V2
#define VIRT_BUT_TAB2_3 V3
#define VIRT_BUT_TAB2_4 V4
#define VIRT_BUT_TAB2_5 V5
#define VIRT_BUT_TAB2_6 V6
#define VIRT_BUT_TAB2_7 V7
#define VIRT_BUT_TAB2_8 V8
#define VIRT_BUT_TAB2_9 V9
#define VIRTUAL_SLIDER V10
#define VIRTUAL_LED V11
#define VIRTUAL_TAB2_CONTROL V20
#define VIRTUAL_TAB3_CONTROL V21
#define VIRTUAL_LED_SPEED V22
#define VIRTUAL_RED_LED_PIN V23
#define VIRTUAL_GREEN_LED_PIN V24
#define VIRTUAL_BLUE_LED_PIN V25
#define VIRTUAL_LED_ANIMATION_1 V31
#define NO_LED_ANIMATION 0
#define BRIGHTNESS 200
#define FRAMES_PER_SECOND 20
WidgetLED led(VIRTUAL_LED);
CRGB ledstrip[NUM_LEDS];
//TAB 2 setting
short gsSliderValue = 1;
short gsSliderValue_Bef = 0;
short gsWhichAnimation = NO_LED_ANIMATION;
unsigned short gusLED_Speed = 20;
unsigned short gusIsNeed_Animation = 0;
unsigned short gusIsNeed_Update = 0;
unsigned short gusTabControl = VIRTUAL_TAB2_CONTROL;
unsigned short gusTabControl_Bef = VIRTUAL_TAB3_CONTROL;
unsigned short gusRGB_Value[] = {0, 255, 255};
unsigned short gusIsBut_Pressed[] = {BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE,BUT_FREE};
unsigned short gusIsBut_Pressed_Bef[] = {1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,};
FastLED.addLeds<CHIPSET, LED_PIN, COLOR_ORDER>(ledstrip, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
led.on();
led.setColor(BLYNK_RED);
Blynk.virtualWrite(VIRTUAL_SLIDER, gsSliderValue);
Blynk.virtualWrite(VIRTUAL_RED_LED_PIN, gusRGB_Value[0]);
Blynk.virtualWrite(VIRTUAL_GREEN_LED_PIN, gusRGB_Value[1]);
Blynk.virtualWrite(VIRTUAL_BLUE_LED_PIN, gusRGB_Value[2]);
Blynk.virtualWrite(VIRTUAL_LED_SPEED, gusLED_Speed);
vCheck_TabControl();
Blynk.syncAll();
char szLabel_On[10];
char szLabel_Off[10];
short sIndex = 0;
//update label
if(gusIsNeed_Update == 0)
for(short i = 1; i <= 10; i++)
if(i == gsSliderValue)
vLabel_Control(i);
gusIsNeed_Update = 1;
vLED_Control();
void vLabel_Control(short sSliderValue)
short sIndex = sGetLED_Index(sSliderValue);
led.on();
for(short i=0; i<10; i++)
if((gusIsBut_Pressed[i+sIndex] != gusIsBut_Pressed_Bef[i+sIndex]) || (sSliderValue != gsSliderValue_Bef) || (gusTabControl != gusTabControl_Bef))
memset(szLabel_On, '\0', sizeof(szLabel_On));
memset(szLabel_Off, '\0', sizeof(szLabel_Off));
if((gusIsBut_Pressed_Bef[i+sIndex] == BUT_LOCKED) || (gusTabControl == VIRTUAL_TAB3_CONTROL))
sprintf(szLabel_On, "%d LOCKED", i+sIndex+1);
sprintf(szLabel_Off, "%d FREE", i+sIndex+1);
if((gusIsBut_Pressed[i+sIndex] == BUT_LOCKED) || (gusTabControl == VIRTUAL_TAB2_CONTROL))
Blynk.virtualWrite(i, HIGH);
gusIsBut_Pressed[i+sIndex] = BUT_LOCKED;
Blynk.virtualWrite(i, LOW);
sprintf(szLabel_On, "%d ON", i+sIndex+1);
sprintf(szLabel_Off, "%d OFF", i+sIndex+1);
Blynk.virtualWrite(i, gusIsBut_Pressed[i+sIndex]);
if(gusIsBut_Pressed[i+sIndex] == BUT_LOCKED)
Blynk.setProperty(i, "color", BLYNK_RED);
Blynk.setProperty(i, "color", BLYNK_DARK_BLUE);
Blynk.setProperty(i, "onLabel", szLabel_On);
Blynk.setProperty(i, "offLabel", szLabel_Off);
gusIsBut_Pressed_Bef[i+sIndex] = gusIsBut_Pressed[i+sIndex];
led.on();
led.setColor(BLYNK_GREEN);
if(sSliderValue != gsSliderValue_Bef)
gsSliderValue_Bef = sSliderValue;
if(gusTabControl != gusTabControl_Bef)
gusTabControl_Bef = gusTabControl;
BLYNK_WRITE(VIRTUAL_LED_SPEED)
gusLED_Speed = param.asInt();
BLYNK_WRITE(VIRTUAL_RED_LED_PIN)
gusRGB_Value[0] = param.asInt();
BLYNK_WRITE(VIRTUAL_GREEN_LED_PIN)
gusRGB_Value[1] = param.asInt();
BLYNK_WRITE(VIRTUAL_BLUE_LED_PIN)
gusRGB_Value[2] = param.asInt();
BLYNK_WRITE(VIRTUAL_LED_ANIMATION_1)
gusIsNeed_Animation = param.asInt();
BLYNK_WRITE(VIRTUAL_SLIDER)
short sSliderValue = param.asInt();
gsSliderValue = sSliderValue;
BLYNK_WRITE(VIRTUAL_TAB2_CONTROL)
short sStatus = param.asInt();
if(sStatus == HIGH)
gusTabControl = VIRTUAL_TAB3_CONTROL;
BLYNK_WRITE(VIRTUAL_TAB3_CONTROL)
if(sStatus == HIGH)
void vCheck_TabControl()
if(gusTabControl == VIRTUAL_TAB2_CONTROL)
Blynk.virtualWrite(VIRTUAL_TAB2_CONTROL, HIGH);
Blynk.virtualWrite(VIRTUAL_TAB3_CONTROL, LOW);
else if(gusTabControl == VIRTUAL_TAB3_CONTROL)
Blynk.virtualWrite(VIRTUAL_TAB2_CONTROL, LOW);
Blynk.virtualWrite(VIRTUAL_TAB3_CONTROL, HIGH);
void vButLock_Set(short sWhichPin, short sOnOff)
short sIndex = sGetLED_Index(gsSliderValue);
//Serial.print("sIndex: ");Serial.println(sIndex);
if(sOnOff == HIGH)
gusIsBut_Pressed[sWhichPin + sIndex] = BUT_LOCKED;
gusIsBut_Pressed[sWhichPin + sIndex] = BUT_FREE;
if(gusIsBut_Pressed_Bef[sWhichPin + sIndex] != BUT_LOCKED)
if(sOnOff == HIGH)
gusIsBut_Pressed[sWhichPin + sIndex] = BUT_PRESSED;
Blynk.virtualWrite(sWhichPin, HIGH);
BLYNK_WRITE(VIRT_BUT_TAB2_0)
vButLock_Set(VIRT_BUT_TAB2_0,sStatus);
BLYNK_WRITE(VIRT_BUT_TAB2_1)
vButLock_Set(VIRT_BUT_TAB2_1,sStatus);
BLYNK_WRITE(VIRT_BUT_TAB2_2)
vButLock_Set(VIRT_BUT_TAB2_2,sStatus);
BLYNK_WRITE(VIRT_BUT_TAB2_3)
vButLock_Set(VIRT_BUT_TAB2_3,sStatus);
BLYNK_WRITE(VIRT_BUT_TAB2_4)
vButLock_Set(VIRT_BUT_TAB2_4,sStatus);
BLYNK_WRITE(VIRT_BUT_TAB2_5)
vButLock_Set(VIRT_BUT_TAB2_5,sStatus);
BLYNK_WRITE(VIRT_BUT_TAB2_6)
vButLock_Set(VIRT_BUT_TAB2_6,sStatus);
BLYNK_WRITE(VIRT_BUT_TAB2_7)
vButLock_Set(VIRT_BUT_TAB2_7,sStatus);
BLYNK_WRITE(VIRT_BUT_TAB2_8)
vButLock_Set(VIRT_BUT_TAB2_8,sStatus);
BLYNK_WRITE(VIRT_BUT_TAB2_9)
vButLock_Set(VIRT_BUT_TAB2_9,sStatus);
short sGetLED_Index(short sSliderValue)
if(sSliderValue == 1) return 0;
else if(sSliderValue == 2) return 10;
else if(sSliderValue == 3) return 20;
else if(sSliderValue == 4) return 30;
else if(sSliderValue == 5) return 40;
else if(sSliderValue == 6) return 50;
else if(sSliderValue == 7) return 60;
else if(sSliderValue == 8) return 70;
else if(sSliderValue == 9) return 80;
else return 90;
I know that i could do this using eventor setProperty setting on Blynk legacy but i read and search everything in documentation and google but nothing found.
Screenshot Blynk legacy eventor:
In automations, we only can change button state to on and off but not the property. and also i tried to use https api but only can update the mutiple pins value but not multiple pins properties.
the link for the https api documentation is also couldnt help bcs nothing is there.
My question is, is there any work around for me to get the same result as in eventor setProperty(Blynk legacy) in Automation (Blynk IOT)
