i have an idea about setting min and max values of widgets like gauge or level. For example, if I have an energy meter and every day it extracts min and max value of power, it would be useful be able to set these values as min and max of gauge widget that displays average power consumpion, in order to have “dynamic” widget that updates every day. The result would be:
Android, version 7.0
I use the function ESP.deepSleep(sleepTime), in order to reduce energy consumption.
I’ve connected the D0 pin with RST pin, and my Wemos wakes up after a delay sleepTime and performs the function of setup().
I wanted to use this function to set the max/min values.
But setting the color and label worked.
Do you set “color”, label and max in that order and straight after each other in your sketch?
Try max first and comment out label, see what that gives you.
Remove the Blynk.setProperty commands from setup and put them in BLYNK_CONNECTED
// only run the commands after you connect and not before so they aren't missed
BLYNK_CONNECTED(){
Blynk.setProperty(V2, "min", 3);
Blynk.setProperty(V2, "max", 5);
