Servo, load cell, ultrasonic also wifi doesnt work, im newbee pleasse help me
so
my app blynk is not connected to wifi even though it is already connected to the board
and my project doesn’t work.
honesty the app blynk once connected but my servo, ultrasonic, loadcell doesn’t work
so, what should i do?
@Memey_Merlian please edit your post, using the pencil icon at the bottom, and remove the blockquotes from your code and put triple backticks at the beginning and end of each sketch so that it displays correctly.
Copy and paste them if necessary.
I’d also suggest that you clarify exactly what this means…
and post your serial monitor output (also between triple backticks).
