Why?
- Pin 3 always do max pwm every (±) 5 seconds?
- Pin 9 can’t do pwm when i setting it?
- All servo have a twitch in every (±) 6 second?
//================================Blynk=======================================
SoftwareSerial DebugSerial(2, 3);
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxx";
//================================Sevo========================================
#include <Servo.h>
Servo Sv1;
Servo Sv2;
int pos1;
int A;
int pos2;
int B;
//=================================PWM=========================================
int C;
int D;
int E;
int F;
int G;
DebugSerial.begin(9600);
Sv1.attach(12);
Sv2.attach(13);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
Blynk.begin(Serial, auth);
BLYNK_WRITE(V8) //FIX
A;
int AN = A;
Serial.print("AN = ");
Serial.print(AN);
Serial.println(" ");
A = param.asInt();
if ( AN <= A)
for (pos1 = AN; pos1 <= A; pos1 += 1)
{ // goes from 0 degrees to 180 degrees
// in steps of 1 degree
Sv1.write(pos1); // tell servo to go to position in variable 'pos'
Serial.print("A+ = ");
Serial.print(pos1);
delay(50); // waits 15ms for the servo to reach the position
else if ( AN >= A)
for (pos1 = AN; pos1 >= A; pos1 -= 1)
Serial.print("A- = ");
Serial.print(pos1);
Serial.print("A = ");
Serial.print(A);
delay(20);
BLYNK_WRITE(V9) //FIX
B;
int BN = B;
Serial.print("BN = ");
Serial.print(BN);
B = param.asInt();
if ( BN <= B)
for (pos2 = BN; pos2 <= B; pos2 += 1)
Sv2.write(pos2); // tell servo to go to position in variable 'pos'
Serial.print("B+ = ");
Serial.print(pos2);
else if ( BN >= B)
for (pos2 = BN; pos2 >= B; pos2 -= 1)
Serial.print("B- = ");
Serial.print(pos2);
Serial.print("B = ");
Serial.print(B);
delay(20);
BLYNK_WRITE(V6) //FIX
int C = param.asInt();
if( C <= 85)
float c = (85.0 - C) * (255.0 / 85.0);
analogWrite(5, c);
digitalWrite(4, LOW);
Serial.print("M1A = ");
Serial.print(c);
if( C >= 170)
float c = (255.0 - C) * (255.0 / 85.0);
analogWrite(5, c);
digitalWrite(4, HIGH);
Serial.print("M1U = ");
Serial.print(c);
else if( C >= 86)
digitalWrite(4, 0);
digitalWrite(5, 0);
Serial.println("Stop");
delay(20);
BLYNK_WRITE(V7) // FIX
D = param.asInt();
if( D <= 85)
float d = (85.0 - D) * (255.0 / 85.0);
analogWrite(6, d);
digitalWrite(7, LOW);
Serial.print("M2A = ");
Serial.print(d);
if( D >= 170)
float d = (255.0 - D) * (255.0 / 85.0);
analogWrite(6, d);
digitalWrite(7, HIGH);
Serial.print("M2U = ");
Serial.print(d);
else if( D >= 86)
digitalWrite(6, 0);
digitalWrite(7, 0);
delay(20);
BLYNK_WRITE(V10)
E = param.asInt();
if( E <= 85)
analogWrite(10, E);
Serial.print("MA = ");
Serial.print(E);
if( E >= 170)
analogWrite(10, E);
Serial.print("MU = ");
Serial.print(E);
else if( E >= 86)
digitalWrite(10, 0);
delay(20);
BLYNK_WRITE(V0)
E = param.asInt();
if( E == 1)
analogWrite(10, 30);
Serial.println("Maju");
BLYNK_WRITE(V1)
E = param.asInt();
if( E == 1)
analogWrite(10, 250);
Serial.println("Mundur");
BLYNK_WRITE(V11)
F = param.asInt();
if( F <= 85)
analogWrite(11, F);
Serial.print(F);
if( F >= 170)
analogWrite(11, F);
Serial.print(F);
else if( F >= 86)
digitalWrite(11, 0);
delay(20);
BLYNK_WRITE(V2)
F = param.asInt();
if( F == 1)
analogWrite(11, 30);
BLYNK_WRITE(V3)
F = param.asInt();
if( F == 1)
analogWrite(11, 250);
BLYNK_WRITE(V4)
G = param.asInt();
if( G == 1)
analogWrite(10, 44);
analogWrite(11, 44);
BLYNK_WRITE(V5)
G = param.asInt();
if( G == 1)
analogWrite(10, 150);
analogWrite(11, 150);
