HI, i connect board hc06 to arduino, and with my smarthphone i use blink for command a servo.
But the servo don’t work. The connection bluetooth is ok.
what do i do? the servo with another skwtch work. i think that the problem is in this code.
in blink i use the button with pin v5 and the value is 0 to 2000.
#include <Servo.h>
char auth[] = "mycode";
Servo servo2;
BLYNK_WRITE(V5)
servo2.write(param.asInt());
DebugSerial.begin(9600);
// 9600 is for HC-06. For HC-05 default speed is 38400
Blynk.begin(Serial, auth);
servo2.attach(5);
I needed to edit your code to format it for proper viewing… in future please post code within this format:
As for your setup… what are you trying to do here?
Servos (using the servo library) take a range of 0-180 (some prefer 0-170)
And you should be using a slider, set for those ranges, for full control, not a button (although that will work for just switching between two positions… but nothing higher than 180.
Also, I don’t think you need this line: #define BLYNK_USE_DIRECT_CONNECT (at least I didn’t)
If it is a servo modified for continuous rotation then stop is usually around the mid point 90 and left/right is either side with speed rising until limit of 0 or 180 is met.
If it is an actual DC motor, then you need a controller board, not direct drive from digital pin.
This is all I require to get a standard servo to work on my Arduino, using Bluetooth:
#define BLYNK_PRINT Serial // Debug console
#include <Servo.h>
char auth[] = "762f6b018xxxxxxxxxxxxxx6eafdfaf9b";
SoftwareSerial SerialBLE(2, 3); // RX TX on Bluetooth
int servoPin = 11;
int SrvoButtonState = 0;
int SrvoPos;
Servo myservo;
pinMode(11, OUTPUT); // Servo Pin
myservo.attach(servoPin);
Serial.begin(9600); // Debug console
SerialBLE.begin(9600); // BT connection
Blynk.begin(SerialBLE, auth);
Serial.println("Connected with Bluetooth!");
BLYNK_WRITE(V0) // Servo Function with button set 1 & 180
SrvoButtonState = param.asInt();
if (SrvoButtonState == 0) {
myservo.write(0);
Blynk.virtualWrite(V6, 0);
} else if (SrvoButtonState == 1) {
myservo.write(180);
Blynk.virtualWrite(V6, 180);
} // END else if
} // END Function
BLYNK_WRITE(V1) // Servo Function with Slider set 0-180
SrvoPos = param.asInt();
myservo.write(SrvoPos);
} // END Function
