hello everyone,
i am trying to control a servo (controlled by a slider which activates the servo relay at 0 and 180) via ifttt (google assistant my case) the only way i could think of is:
-“PUT” via webhook the values 0 or 180 in the servo vpin (V25 my case)
-use eventor to activate the servo power relay at values 0 or 180. (works manually from the app, servo relay V21)
i already control normal vpins of relays (lights) successfully but i am not successful with the servo, since after i send the webhook the slider in the app does not change its position or value
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
// define the physical pins the relays are connected to. Make sure you use GPIO numbers and not D numbers. D6 = GPIO12 etc
#define RELAY1_PIN 5 // D1
#define RELAY2_PIN 4 // D2
#define RELAY3_PIN 14 // D5
#define RELAY4_PIN 12 // D6
#define servoPin D0 // D0
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <ArduinoOTA.h>
#include <Servo.h>
char auth[] = "token";
char ssid[] = "FRITZ!Box 3490";
char pass[] = "password";
char hostOTA[] = "OTAUpdates";
char passOTA[] = "1234";
WidgetRTC rtc;
Servo servo;
// Digital clock display of the time
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
// Send time to the App
Blynk.virtualWrite(V1, currentTime);
// Send date to the App
Blynk.virtualWrite(V2, currentDate);
void turnRelayOff() {
digitalWrite(RELAY1_PIN, HIGH);
Blynk.virtualWrite(V21, LOW);
void uptimer()
static unsigned long lastTimeUpdateMillis = 0;
if(millis() - lastTimeUpdateMillis > 1000)
char str[15] = "";
timeToString(str, sizeof(str));
Blynk.virtualWrite(V3, str);
lastTimeUpdateMillis = millis();;
// t is time in seconds = millis()/1000;
void timeToString(char* string, size_t size)
unsigned long nowMillis = millis();
unsigned long seconds = nowMillis / 1000;
int days = seconds / 86400;
seconds %= 86400;
byte hours = seconds / 3600;
seconds %= 3600;
byte minutes = seconds / 60;
seconds %= 60;
snprintf(string, size, "%04d:%02d:%02d:%02d", days, hours, minutes, seconds);
// Keep this flag not to re-sync on every reconnection
bool isFirstConnect = true;
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncVirtual(V21, V22, V23, V24, V25);
isFirstConnect = false;
servo.attach(servoPin);
// Begin synchronizing time
rtc.begin();
// Other Time library functions can be used, like:
// timeStatus(), setSyncInterval(interval)...
// Read more: http://www.pjrc.com/teensy/td_libs_Time.html
// Display digital clock every 1 seconds
timer.setInterval(1000L, clockDisplay);
timer.setInterval(1517L, uptimer);
ArduinoOTA.setHostname(hostOTA);
//ArduinoOTA.setPassword(passOTA);
ArduinoOTA.onStart([]() {
Serial.println("OTA: Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nOTA: End");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("OTA: Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("OTA: Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("OTA: Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("OTA: Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("OTA: End Failed");
ArduinoOTA.begin();
Serial.println("OTA: Ready");
pinMode(RELAY1_PIN,OUTPUT);
pinMode(RELAY2_PIN,OUTPUT);
pinMode(RELAY3_PIN,OUTPUT);
pinMode(RELAY4_PIN,OUTPUT);
digitalWrite(RELAY1_PIN, HIGH); // most modules are LOW active... so on boot start inactive (HIGH)
digitalWrite(RELAY2_PIN, HIGH); // most modules are LOW active... so on boot start inactive (HIGH)
digitalWrite(RELAY3_PIN, HIGH); // most modules are LOW active... so on boot start inactive (HIGH)
digitalWrite(RELAY4_PIN, HIGH); // most modules are LOW active... so on boot start inactive (HIGH)
BLYNK_WRITE(21){ // virtual pin 21... create a button widget in SWITCH mode
if(param.asInt()){
digitalWrite(RELAY1_PIN, LOW); // if button is HIGH, turn on relay1
timer.setTimeout(780, turnRelayOff);
digitalWrite(RELAY1_PIN, HIGH); // if button is LOW, turn off relay1
BLYNK_WRITE(22){ // virtual pin 22... create a button widget in SWITCH mode
if(param.asInt()){
digitalWrite(RELAY2_PIN, LOW); // if button is HIGH, turn on relay1
digitalWrite(RELAY2_PIN, HIGH); // if button is LOW, turn off relay1
BLYNK_WRITE(23){ // virtual pin 23... create a button widget in SWITCH mode
if(param.asInt()){
digitalWrite(RELAY3_PIN, LOW); // if button is HIGH, turn on relay1
digitalWrite(RELAY3_PIN, HIGH); // if button is LOW, turn off relay1
BLYNK_WRITE(24){ // virtual pin 24... create a button widget in SWITCH mode
if(param.asInt()){
digitalWrite(RELAY4_PIN, LOW); // if button is HIGH, turn on relay1
digitalWrite(RELAY4_PIN, HIGH); // if button is LOW, turn off relay1
BLYNK_WRITE(V25){
Blynk.virtualWrite(V25, param.asInt());
servo.write(param.asInt());
timer.run(); // BlynkTimer is working...
ArduinoOTA.handle();
if you think of better ways please tell me
