Hello i have issue
Today i found solution why i was getting timeout when using BH1750 i solved it. It works fine. Then i wanted to implement servo motors but when i included servo.h i started getting timeout
I tried code in ofline first and it worked.
#define BLYNK_TEMPLATE_ID "****"
#define BLYNK_TEMPLATE_NAME "*****"
#define BLYNK_AUTH_TOKEN "****"
#define EspSerial Serial
#define ESP8266_BAUD 115200
#define cas 10000
#define red 7
#define sound 5
#include <ESP8266_Lib.h>
#include <BH1750.h>
#include <Servo.h>
unsigned long newtime = 0;
int number = 0;
int wire = 0;
int stat;
int last;
int nove = 0;
int OS = 0;
int ZS = 120;
int OD = 179;
int ZD = 20;
char ssid[] = "*****";
char pass[] = "****";
ESP8266 wifi(&EspSerial);
BH1750 lightMeter;
Servo Door;
Servo Silo;
void sendData(void)
if(millis() > newtime + cas)
float lights = lightMeter.readLightLevel();
Wire.begin();
Wire.write(number);
Wire.end();
newtime = millis();
if(lights > 1)
number = 1;
void sendSensor()
float light = lightMeter.readLightLevel();
float lastH = light;
lightMeter.begin();
Wire.begin();
Wire.write(number);
Wire.end();
newtime = millis();
if(light > 1)
number = 1;
Blynk.virtualWrite(V6, light);
if(light <= lastH && light <= 0)
stat = 0;
if(light >= lastH && light >= 1) //den
stat = 1;
last = stat;
if(stat == 1) //den
if(nove != last)
analogWrite(red, 255);
delay(500);
analogWrite(sound,80);
analogWrite(sound,255);
Silo.write(OS);
delay(2000);
Silo.write(ZS);
nove = 1;
Door.write(179);
delay(2000);
analogWrite(red, 0);
Serial.println("dzen");
if(stat == 0) //noc
Serial.println("cma");
if(nove != last)
delay(5000);
Door.write(ZD);
delay(5000);
nove = 0;
Blynk.begin(auth, wifi, ssid, pass, "blynk.cloud", 80);
timer.setInterval(2000L, sendSensor);
Silo.attach(3);
Door.attach(2);
Door.write(ZD);
Silo.write(ZS);
Where could be problem ?
Ps: i know that the code looks horible…
