it is very useful feature that we have some mutual Virtual pins on Raspberry(as Server), The Pin that be mutual on every other device, with this feature we do mutual process such as temp and sunrise , … and send to other device that need to shown or receive that info.
Sounds like a use for the Bridge widget.
Bridge is good feature but it require some code and limited access to change after Upload the code.
If you use an ESP as the master and all other devices as slaves you can update the master over the internet.
How do it?
@s.d.engineering any none ESP’s, i.e. Arduino’s send their data via bridge to the ESP.
The internet updates are available with the sketches in your IDE under File, Examples and ESP8266httpUpdate.
Hello. Yeap, we have this idea too. Actually it may allow to avoid using bridge that is hard for many people.
Good luck. And waitting… To many new Feature.
