SGP server down ? Cant login without vpn and esp32 device was offline ? I want to know server down or block Myanmar ?
Hello @Loker.
SGP server down ?
All fine with server
Cant login without vpn and esp32 device was offline ? I want to know server down or block Myanmar?
This not Blynk side. I guess this could be your internet provider issue/block
Now i can use again application and esp.Thank you for your replay😀
Sir One question pls blynk cant open application myanmar region that was appeared befor 3 week of period is depended on myanmar isp ?
If they can block or ban cant login blynk in the future ?
What can i do for that problem ?
When about issue time I use vpn blynk app was opened but blynk v pin cant reach to my esp32.
Blynk currently has 5 servers around the world.
Your Blynk account will only be on one of those servers.
For Blynk to work correctly, your app, devices and Web console (if you use it) all need to be connected to the same server.
This is the list of servers…
https://fra1.blynk.cloud/ – Frankfurt
https://lon1.blynk.cloud/ – London
https://ny3.blynk.cloud/ – New York
https://sgp1.blynk.cloud/ – Singapore
https://blr1.blynk.cloud/ – Bangalore
When you use VPN on your mobile device but not on your home network, or if the VPNs cause the devices to resolve blynk.cloud via different DNS servers then they will try to connect to different servers.
