Server-0.23.5.jar not starting
Exception in thread "main" java.lang.RuntimeException: File does not contain valid private key: .\server_embedded.pem
        at cc.blynk.utils.SslUtil.initSslContext(SslUtil.java:71)
        at cc.blynk.server.hardware.HardwareSSLServer.<init>(HardwareSSLServer.java:36)
        at cc.blynk.server.launcher.ServerLauncher.start(ServerLauncher.java:78)
        at cc.blynk.server.launcher.ServerLauncher.main(ServerLauncher.java:70)
    indent preformatted text by 4 spaces
Server 0.23.3 was ok
Blynk Server 0.23.3 successfully started.
All server output is stored in folder 'C:\Blynk_Server\.\logs' file.
Hello. What is your server.properties?
@Dmytro
Hello
my server.properties
#hardware mqtt port
hardware.mqtt.port=8440
#hardware ssl port
hardware.ssl.port=8441
#hardware plain tcp/ip port
hardware.default.port=8442
#http port
http.port=8080
#web sockets ssl port
ssl.websocket.port=8081
#web sockets plain tcp port
tcp.websocket.port=8082
#https port
https.port=9443
#application ssl port
app.ssl.port=8443
#by default server uses embedded in jar cert to simplify local server installation.
#WARNNING DO NOT USE THIS CERTIFICATES ON PRODUCTION OR IN WHERE ENVIRNOMENTS REAL SECURITY REQUIRED.
#provide either full path to files either use '.' for specifying current directory. For instance "./myfile.crt"
server.host=
server.ssl.cert=./server_embedded.crt
server.ssl.key=./server_embedded.pem
server.ssl.key.pass=
#Blynk server allows to use 2 hosts for same IP, below properties for second host
server2.host=
server2.ssl.cert=./server_embedded.crt
server2.ssl.key=./server_embedded.pem
server2.ssl.key.pass=
client.ssl.cert=
client.ssl.key=
#by default System.getProperty("java.io.tmpdir")/blynk used
data.folder=
#folder for logs.
logs.folder=./logs
#log debug level. trace|debug|info|error. Defines how precise logging will be.
log.level=info
#defines maximum allowed number of user dashboards. Needed to limit possible number of tokens.
user.dashboard.max.limit=10
#defines maximum allowed widget size in KBs as json string.
user.widget.max.size.limit=10
#user is limited with 100 messages per second.
user.message.quota.limit=100
#in case of consistent quota limit exceed during long term, sending warning response back to exceeding channel
#for performance reason sending only 1 message within interval. In millis
user.message.quota.limit.exceeded.warning.period=60000
#maximum allowed number of notification queue. Queue responsible for processing email, pushes, twits sending.
#Because of performance issue - those queue is processed in separate thread, this is required due
#to blocking nature of all above operations. Usually limit shouldn't be reached.
notifications.queue.limit=10000
#Number of threads for performing blocking operations - push, twits, emails, db queries.
#Recommended to hold this value low unless you have to perform a lot of blocking operations.
blocking.processor.thread.pool.limit=5
#this setting defines how often we can send mail/tweet/push or any other notification. Specified in seconds
notifications.frequency.user.quota.limit=60
#maximum size of user profile in kb's
user.profile.max.size=128
#period in millis for saving all user DB to disk.
profile.save.worker.period=60000
#period in millis for saving stats to disk.
stats.print.worker.period=60000
#specifies maximum period of time when application socket could be idle. After which
#socket will be closed due to non activity. In seconds. Default value 600 if not provided.
#leave it empty for infinity timeout
app.socket.idle.timeout=600
#specifies maximum period of time when hardware socket could be idle. After which
#socket will be closed due to non activity. In seconds. Default value 15 if not provided.
hard.socket.idle.timeout=15
#Enables native socket transport for Linux using JNI. Should be turned on only if you 100% sure.
#may not work on some environments. Used to increase server performance. Performance boost is ~20-40%.
enable.native.epoll.transport=false
#Enabled native openSSL support for SSL handlers. Should be turned on only if you 100% sure.
#may not work on some environments. Used to increase server performance. Performance boost is ~16%.
#For more details see - http://netty.io/wiki/forked-tomcat-native.html
enable.native.openssl=false
#mostly required for local servers setup in case user want to log raw data in CSV format
#from his hardware
#enable.raw.data.store=true
#enable raw data storage to DB
enable.raw.db.data.store=false
#size of async logger ring buffer. should be increased for loads >2-3k req/sec
async.logger.ring.buffer.size=8192
#ADMINISTRATION SECTION
admin.rootPath=/admin
#administration https port
administration.https.port=9443
#reset pass port
reset.pass.http.port=7444
#host for reset pass redirect. by default current server IP is taken. could be replaced with more friendly hostname.
#it is recommended to override this property with your server IP to avoid possible problems of host resolving
reset-pass.http.host=blynk-cloud.com
#comma separated list of administrator IPs. allow access to admin UI only for those IPs.
#you may set it for 0.0.0.0/0 to allow access for all.
#you may use CIDR notation. For instance, 192.168.0.53/24
allowed.administrator.ips=127.0.0.1
#comma separated list of users allowed to create accounts. leave it empty if no restriction required.
allowed.users.list=
You need to have :
server.ssl.cert=
server.ssl.key=
In case you don’t use own certificates.
@Dmytro
What do you mean by this screen?
ssl cert and keys are there
How empty fields “are there”? Sorry, I do not understand what you are trying to say.
in my server.properties fields are not empty.
could you please explain.
server.host=
server2.host=
I explained above
did you read what i am typing?
Yes. And I gave you an answer of what you should do.
ok
where can i find a tutorial ?
as me and many others knows nothing in java.
Here you can find many requests.
You just have outdated configs. That’s all. It is not related to java.
@Dmytro @Pavlo
More Help is needed
Continuing the discussion from Local Blynk Server Tutorial:
WARNING: You should have password for certificate. Certificates without passwords are not accepted.
openssl pkcs8 -topk8 -inform PEM -outform PEM -in server.key -out server.pem
can you tell us how to?
@Ze_Pico from memory it should ask you for a password as part of the process when you issue the command.
This was fixed and password is not required anymore. However in case of those instruction you should be promted with password.
@Costas
Hi Costas
yes. but it don’t accept any entry. " only the enter key"
C:\My_Server>openssl pkcs8 -topk8 -inform PEM -outform PEM -in server.key -out server.pem
Enter Encryption Password:
Verifying - Enter Encryption Password:
Verify failure
can you try it for me.
