Hi guys I need help with my project I got two blink codes for two different sensors I want to compile them together in one code
fist code for temperature sensor
#include <OneWire.h>
OneWire oneWire(D2); // digital D2 pin
char auth[] = "kZ3kWJq4s42Nq8fcey43RNx-v7AOxOFE";
char ssid[] = "Shahrul";
char pass[] = "azlanDazman";
float temp = 0;
sensors.begin();
timer.setInterval(1000L, sendTemps);
void sendTemps()
temp = sensors.getTempCByIndex(0);
Serial.println(String("Sıcaklik=")+temp+ String(" C"));
Blynk.virtualWrite(V1, temp);
second code for PH sensor
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
char auth[] = " jg_jGwBe3YXwxVV7xS-628sYP1uibX1M";
char ssid[] = "Utemhomies";
char pass[] = "38tu28697";
WidgetLCD lcd(V0);
float calibration_value = 26.84 - 0.7;
int phval = 0;
unsigned long int avgval;
int buffer_arr[10],temp;
float ph_act;
Wire.begin();
for(int i=0;i<10;i++)
buffer_arr[i]=analogRead(A0);
delay(30);
for(int i=0;i<9;i++)
for(int j=i+1;j<10;j++)
if(buffer_arr[i]>buffer_arr[j])
temp=buffer_arr[i];
buffer_arr[i]=buffer_arr[j];
buffer_arr[j]=temp;
avgval=0;
for(int i=2;i<8;i++)
avgval+=buffer_arr[i];
float volt=(float)avgval*5.0/1024/6;
ph_act = -4.6 * volt + calibration_value;
Serial.print("'Group 5 IDP' pH Val: ");
Serial.println(ph_act);
lcd.print(0,0,"pH Value:");
lcd.print(0,1,ph_act);
thank you
