Hi guys, I’m trying to connect the ultrasound sensor using the USB port to view it in the web application but it doesn’t work. Can somebody help me
#define BLYNK_DEVICE_NAME "jjj"
#define BLYNK_AUTH_TOKEN "vSVLVXD_jjFbpxHNZlAkxwsT9D64Zt-p"
#define BLYNK_PRINT SwSerial
SoftwareSerial SwSerial(0, 1); // RX, TX
#define echoPin 11
#define trigPin 10
long duration;
int distance;
void sendSensor()
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
distance = duration * 0.034 / 2; //formula to calculate the distance for ultrasonic sensor
Serial.print("Distance: ");
Serial.println(distance);
Blynk.virtualWrite(V0, distance);
SwSerial.begin(9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
Blynk.begin(Serial, auth);
