I am having an issue sending a temperature (e.g. 15.5 ) to Blynk 2
I have set my Virtual data as decimal in Blynk.Console and then when I do a virtualWrite “Blynk.virtualWrite(V10,myValue)” and send the data as a float or int I get a zero in my Widgit (tried using Valued Label, Labeled value and also a Guage.)
I can get the data to display if I change the type to String in the virtual pin in the Console bit that seems wrong as I get no formatting etc… Am I doing something wrong?
Sorry my mistake - I said decimal in my initial msg but I should have typed “double” as decimal is not even an option. Any way it is set as double and still doesn’t work.
No because it’s obvious, any blynk user knows that there must be min and max values, for example when you create a switch you have to put 0 and 1 or else it’s not gonna work.
