zimb
January 28, 2017, 12:37pm
1
Hey Guys,
i have tried to send Messages with the Blynk webhook and a Telegram Bot.
With Curl it is not a Problem but when i try to configure the url in Webhook i get an URL Malformed Error.
Here ist my URL (changed IDs):
https://api.telegram.org/botxxxxxxxxxxx123key/sendMessage?-d?chat_id=-23168065?-d?text= “This is a Test”
Can Someone Help me?
Greetings Zimb
Costas
January 28, 2017, 12:43pm
2
It will probably be the text=“This is a Test” part.
Online url encoders convert that part to:
text%3D%22This+is+a+Test%22
zimb
January 28, 2017, 12:54pm
3
Hello Costas,
i have tried it but doesnt Work.
https://api.telegram.org/bot272089:AAGrjUsUYLpyv3R3f0nHfG4WFMGA/sendMessage -d chat_id=154546328 -d text=“test123”
This format works in CURL
Costas
January 28, 2017, 1:01pm
4
Try the urlencoder at http://www.url-encode-decode.com/
Maybe your original sample should end with
Dmytro
January 28, 2017, 1:19pm
5
Please show us URL you are trying to put in webhook widget. Above url doesn’t seem correct to me.
zimb
January 28, 2017, 1:22pm
6
Dmytro
January 28, 2017, 1:24pm
7
Does it work from browser for you?
zimb
January 28, 2017, 1:28pm
8
Hello Dimitriy jey with my new format!
Tanks for Help to all!
Hi! So I got my telegram url working from my webbrowser, but not from webhooks-widget in the app… http://api.telegram.org/bot494291172:AAGV9fXVcuDSrfu_tB9MP1kkQWsI3Whlxxx/sendMessage?chat_id=-257978xxx&text=This is a test
I have some questions:
Do I have to convert the whole thing or just parts of it with URL encoder?
I want to send telegram message when D5 goes high, do I have to modify Nodemcu-program other than routing D5 to a virtual pin?
Do the rest of the parameters in the Webhooks widget have to be set up in a certain way for it to work?
thanks,
Henrik
Dmytro
June 26, 2018, 10:43am
10
@jalapenos you put the wrong url into the webhook. Instead “http://api.telegram.org ” you put " http%3A%2F%2Fapi.telegram.org %2F"
Parameters could be encoded, but not the schema (http://) part
Yeap.
