FOR THE ESP32:
const char* fwUrlBase = "http://yourserver.com/.fota/"; /// put your server URL where the *.bin & *.version files are saved in your http ( Apache? ) server
const int FW_VERSION = 2019041802 ; /// year_month_day_counternumber 2019 is the year, 04 is the month, 17 is the day 01 is the in day release
#define Version "0.5" /// sketch version ///
/// Blynk related setup ///
* V1 virtual switch for activate or deactivate RUNning LED controlling (boolean) ledBlink
* V14 WidgetTerminal terminal V14
* V20 virtual switch in push button mode, for on demand OTA
* V21 RUNning virtual LED
* V26 virtual switch in push button mode, to activate HTTP file OTA on demand via boolean HTTP_OTA variable that activate in the loop V26
const char* ssid = "mywifiap"; /// put your AP SSID here
const char* password = "12345678"; /// put your AP PASSWORD oy KEY here
#define HARDWARE_LED 5 /// GPIO05 /// sparkfun ESP32 thing LED
/// ESP32 HTTP OTA dependencies ///
#include <Arduino.h> /// FOR ESP32 HTTP FOTA UPDATE ///
#include <WiFi.h> /// FOR ESP32
#include <HTTPClient.h> /// FOR ESP32 HTTP FOTA UPDATE ///
#include <HTTPUpdate.h> /// FOR ESP32 HTTP FOTA UPDATE ///
#include <WiFiClient.h> /// FOR ESP32 HTTP FOTA UPDATE ///
WiFiClient client; /// FOR ESP32 HTTP FOTA UPDATE ///
/// blynk dependencies ///
#include <BlynkSimpleEsp32.h> /// FOR ESP32
char auth[] = "puthereyourBlynkAUTHnumber";
// Attach virtual serial terminal to Virtual Pin V14
WidgetTerminal terminal(V14);
WidgetLED led0(V21);
/// SimpleTimer timer;
/// switch value to control if the WeMos internal led will be blinking if HIGH or not if LOW ///
boolean ledBlink = true;
/// timestamp variable to keep track of millis() unsigned long ticks = millis() / 1000; That is for debugging printings ///
unsigned long timestamp;
/// for HTTP based file OTA update ///
bool HTTP_OTA = false; /// we control this boolean variable through V26 switch that is in push button mode
/// START routine for manual (on demand) requesting HTTP file OTA. Virtual Button SW V26 is used ///
BLYNK_WRITE(V26)
if (param.asInt()) {
HTTP_OTA = true;
else {
HTTP_OTA = false;
/// END routine for manual (on demend) requesting HTTP file OTA. Virtual Button SW V15 is used ///
/// START of SimpleTimer timer activating function blinkLedWidget ///
void blinkLedWidget()
if (led0.getValue()) {
led0.off();
///BLYNK_LOG("LED0: off");
led0.on();
///BLYNK_LOG("LED0: on");
/// END of SimpleTimer timer activating function blinkLedWidget ///
/// put the routine here to blink WeMos LED (D4) each ? second(s), using the "control software switch" ledBlink ///
if (ledBlink)
{int test = digitalRead(HARDWARE_LED); /// Could also be : pinMode(BUILTIN_LED, OUTPUT); OR digitalRead(BUILTIN_LED); /// onboard LED as output
digitalWrite(HARDWARE_LED, !test);
/// Start of main function that performs HTTP OTA ///
void checkForUpdates() {
uint8_t mac[6];
char macAddr[14];
WiFi.macAddress( mac );
///sprintf(macAddr,"%02x%02x%02x%02x%02x%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]); /// small letters at MAC address
sprintf(macAddr, "%02X%02X%02X%02X%02X%02X", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]); /// capital letters at MAC address
///terminal.println(macAddr);
Blynk.virtualWrite(V14, macAddr);
String fwURL = String( fwUrlBase );
fwURL.concat( macAddr );
String fwVersionURL = fwURL;
fwVersionURL.concat( ".version" );
Serial.println( "Checking for firmware updates." );
Serial.print( "MAC address: " );
Serial.println( macAddr );
Blynk.virtualWrite(V14, "\nChecking for firmware updates.\nMAC address: ");
Serial.print( "Firmware version URL: " );
Serial.println( fwVersionURL );
Blynk.virtualWrite(V14, "\nFirmware version URL: ");
Blynk.virtualWrite(V14, fwVersionURL);
HTTPClient httpClient;
httpClient.begin( client, fwVersionURL );
int httpCode = httpClient.GET();
if( httpCode == 200 ) {
String newFWVersion = httpClient.getString();
Serial.print( "Current firmware version: " );
Serial.println( FW_VERSION );
Serial.print( "Available firmware version: " );
Serial.println( newFWVersion );
Blynk.virtualWrite(V14, "\nCurrent firmware version: ");
Blynk.virtualWrite(V14, FW_VERSION);
Blynk.virtualWrite(V14, "\nAvailable firmware version: ");
Blynk.virtualWrite(V14, newFWVersion);
int newVersion = newFWVersion.toInt();
if( newVersion > FW_VERSION ) {
Serial.println( "Preparing to update" );
Blynk.virtualWrite(V14, "\nPreparing to update");
String fwImageURL = fwURL;
fwImageURL.concat( ".bin" );
t_httpUpdate_return ret = httpUpdate.update( client, fwImageURL ); /// FOR ESP32 HTTP FOTA
switch(ret) {
case HTTP_UPDATE_FAILED:
Serial.printf("HTTP_UPDATE_FAILD Error (%d): %s", httpUpdate.getLastError(), httpUpdate.getLastErrorString().c_str()); /// FOR ESP32
char currentString[64];
sprintf(currentString, "\nHTTP_UPDATE_FAILD Error (%d): %s\n", httpUpdate.getLastError(), httpUpdate.getLastErrorString().c_str()); /// FOR ESP32
Blynk.virtualWrite(V14, currentString);
break;
case HTTP_UPDATE_NO_UPDATES:
Serial.println("HTTP_UPDATE_NO_UPDATES");
Blynk.virtualWrite(V14, "\nHTTP_UPDATE_NO_UPDATES\n");
break;
else {
Serial.println( "Already on latest version" );
Blynk.virtualWrite(V14, "\nAlready on latest version\n");
else {
Serial.print( "Firmware version check failed, got HTTP response code " );
Serial.println( httpCode );
sprintf(currentString, "\nFirmware version check failed, got HTTP response code : %d\n",httpCode);
httpClient.end();
/// End of main function that performs HTTP OTA ///
/// START OF SETUP ///
Serial.println("Booting...");
/// on board LED ///
pinMode(HARDWARE_LED, OUTPUT);
WiFi.mode(WIFI_STA);
Serial.println(WiFi.macAddress()); /// PRINT MAC ADDRESS TO SERIAL ... use this in order to see the MAC Address that is used for the http FOTA update
WiFi.begin(ssid, password);
if (WiFi.status() != WL_CONNECTED) {
Serial.println("Connecting to Wifi AP...");
for ( int i = 0; i < 300; i++) { /// try to connect to WiFi for max 30s
if (WiFi.status() == WL_CONNECTED) {
Serial.printf("it is connected after %d seconds",(i/10));
break; }
yield();
delay(100);
if(WiFi.status() == WL_CONNECTED) {
//if you get here you have connected to the WiFi
Serial.println("\nconnected...yesss! :)");
Serial.println("TimeOut! Not Connected even after 10 Seconds trying...\n *** Something wrong happened. It did not connected... *** ");
/// Blynk.begin(auth, ssid, password);
Serial.println("connected...yesss! :)");
Serial.println("Ready");
Serial.print("IP address: ");
unsigned long maxMillis=millis() + 50000;
Blynk.config(auth);
Serial.println(" Trying to connected to Blynk... ");
Serial.printf(" Enter millis is: %d\n",millis());
do {
// Wait until connected or 10 seconds passed without connection ( maxMillis )
if(Blynk.connect() == true) {
Serial.println(" Blynk is connected !!! ... ");
Serial.printf(" Break millis is: %d\n",millis());
break;
yield();
delay(200);
} while ((Blynk.connect() == false) && ( millis() < maxMillis));
Serial.printf(" Exit millis is: %d\n",millis());
if(Blynk.connect() == false) Serial.println(" Not Connected to Blynk. Something wrong happens... ");
if(Blynk.connect() == true) Serial.println(" Blynk is connected!!! ... ");
pinMode(HARDWARE_LED, OUTPUT); // initialize onboard LED as output
digitalWrite(HARDWARE_LED, HIGH); // dim the LED
Serial.println(FW_VERSION);
/// start of SimpleTimer timer Functions
/// This blink LED function be called every 2 seconds
timer.setInterval(2000L, blinkLedWidget);
/// end of SimpleTimer timer Functions
/// END OF SETUP ///
/// start routine for V1 controlling ledBlink boolean global variable ///
BLYNK_WRITE(V1)
{ char currentMillis[64];
sprintf(currentMillis, "\n\n Enter millis()= %d",millis());
Blynk.virtualWrite(V14, currentMillis);
ledBlink = true;
digitalWrite(HARDWARE_LED, HIGH); /// switch off the internal LED
else {
sprintf(currentMillis, "\n\n Exit millis()= %d",millis());
ledBlink = false;
digitalWrite(HARDWARE_LED, HIGH); /// switch on the internal LED
/// end of routine for V1 controlling ledBlink boolean global variable ///
/// start routine for manual (on demand) requesting OTA The Virtual Button SW V20 is used ///
BLYNK_WRITE(V20)
//// ArduinoOTA.handle(); /// ESP8266 OTA
/// end of routine for manual (on demand) requesting OTA The Virtual Button SW V20 is used ///
// This function will run every time Blynk connection is established
BLYNK_CONNECTED() {
/// if (isFirstConnect) {
// Request Blynk server to re-send latest values for all pins
Blynk.syncAll();
/// START OF LOOP ///
if(HTTP_OTA) {
/// shall I stop timers and Blynk related in order to ensure succesful WEB OTA ??? ///
checkForUpdates();
} /// We need this in order to do WEB file OTA update ///
/// END OF LOOP ///
