Segmented Switch property
what are the Blynk.setProperty of the Segmented Switch ?
You can set standard color and also labels property (same as Menu widget)
thank you,
I suppose there is more options like ON and OFF colors for each button
You cannot set individual colors for each item.
ah, ok …
thank you
I’ll try this evening
Oh, if anyone can make it happen anyhow, I suspect @Blynk_Coeur will :stuck_out_tongue:
may be , may be :wink:
