BLYNK
Segmented switch label rename not applied
Hi. Appreciate a look at behavior below. Actually I am not sure it’s a bug considering that the source datastream is an enumerable. Just wanted to make sure. Thanks.
ESP32, WiFi
Android Android 13.
Blynk Server. ny3 region
• Blynk Library version
Blynk library version 1.2.0
Blynk App version: 1.9.1 (122) 17.05.2023 10:59 (latest in play store)
Issue: Renaming the segments label is no applied. Note that the source datastream is a enumerable type. See screen cast below:
Well, the documentaion does say…
NOTE : Changing these parameters work only for widgets attached to Virtual pins (analog/digital pins won’t work).
https://docs.blynk.io/en/blynk-library-firmware-api/widget-properties
Thank you. My bad about this report.
