Running an mqtt client connected to the blynk broker from ec2 instance
Hi all. Would appreciate if someone could help. I am trying to create an EC2 instance to send some data to blynk using mqtt. The same code running in the EC2 instance has been run on the edge (on the rpi itsself) and works.
I have double checked the authentication information and I even get confirmation that the client is connected to the broker, however, i still see the device offline and cannot update any of my datastreams.
has anyone run into a similar problem and can help? Thanks in advance
