RTC widget show date time wrong
//#include <Ethernet.h>
//#include <BlynkSimpleEthernet.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <Servo.h>
LiquidCrystal_I2C lcd(0x3F,16,2);
Servo servo;
char auth[] = "";
const char* ssid = "";                  //ใส่ชื่อ SSID Wifi
const char* password = "";          //ใส่รหัสผ่าน
WidgetRTC rtc;
BLYNK_WRITE(V3) {
servo.write(param.asInt());
// Digital clock display of the time
void clockDisplay()
  // You can call hour(), minute(), ... at any time
  // Please see Time library examples for details
  Serial.print(currentTime);
  Serial.print(" ");
  Serial.print(currentDate);
  Serial.println();
  // Send time to the App
  Blynk.virtualWrite(V1, currentTime);
  // Send date to the App
  Blynk.virtualWrite(V2, currentDate);
  lcd.begin();                      // initialize the lcd
  lcd.backlight();
  lcd.setCursor(0,0);
  lcd.print(currentTime);
  lcd.setCursor(0,1);
  lcd.print(currentDate);
BLYNK_CONNECTED() {
  // Synchronize time on connection
  rtc.begin();
  Blynk.begin(auth, ssid, password);
  // Other Time library functions can be used, like:
  //   timeStatus(), setSyncInterval(interval)...
  // Read more: http://www.pjrc.com/teensy/td_libs_Time.html
  setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
  // Display digital clock every 1 seconds
  timer.setInterval(1000L, clockDisplay);
  servo.attach(2);
this the results start by
0 : 0 : 0
1 / 1 / 1970
Perhaps you should start with a little basic research and search this forum for the keywords RTC, 1970 :stuck_out_tongue_winking_eye:
Blynk - RE-SEAR-CH
And while you are reading up on RTC, please make sure you are running current versions of App, Libraries and if you are using it, Local Server.
