I am using the RTC widget for my project. Everything seems fine but when my device runs the time is not correct. IT shows the year 1970 like this.
Can someone please help me with this? @Costas @Dave1829 @Lichtsignaal
i am not sure,
my Arduino Mega on Ethernet works with Blynk’s RTC, but my ESP8266 does not work with the Blynk RTC…
i have been meaning to follow it up, but it is not at the top of my list…
I get the same error while using my Arduino Uno with ethernet shield and with CC3000. I just don’t know how to figure it out
I see you use an old library. It may help to upgrade that
Once you have upgraded to the latest library try the RTC sketch and see what it gives you https://github.com/blynkkk/blynk-library/blob/master/examples/Widgets/RTC/RTC.ino
i fixed my ESP8266 RTC widget error by moving the RTC virtual pin from V36 to V23
@Costas - i need to delve into the issues around the 128 pin upgrade… it is now showignn gremlins on my ESP stuff…
