I’m trying to use the RTC widget on my project, I’m running latest version of IOS, latest version of blynk app, latest server version and latest arduino IDE library. My problem is that I can’t read a real time, whenever I reset the wemos D1 mini pro, the time starts in 00:00
This is my code:
#define BLYNK_DEBUG
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#define LED BUILTIN_LED
bool isFirstConnect = true;
char auth[] = "7147415706734becb602fac38b680ed4";
SimpleTimer Timer;
String muestraWifiyHora = " ";
int wifisignal;
WidgetTerminal terminal(V3);
WidgetRTC rtc;
void CheckConnectionProc()
if (!Blynk.connected()) {
if(Blynk.connect()) {
Serial.println("Reconexion OK");
Serial.println("Reconexion no OK");
void calculaRSSIyReloj()
wifisignal = map(WiFi.RSSI(), -105, -40, 0, 100);
int gmthour = hour();
if (gmthour == 24){
gmthour = 0;
String hora = String(gmthour, DEC);
int horadigitos = hora.length();
if(horadigitos == 1){
hora = "0" + hora;
String minutos = String(minute(), DEC);
int minutosdigitos = minutos.length();
if(minutosdigitos == 1){
minutos = "0" + minutos;
String reloj = hora + ":" + minutos;
muestraWifiyHora = " Señal: ";
muestraWifiyHora = muestraWifiyHora + wifisignal;
muestraWifiyHora = muestraWifiyHora + "%";
muestraWifiyHora = muestraWifiyHora + " Reloj: ";
muestraWifiyHora = muestraWifiyHora + reloj;
Blynk.setProperty(V3, "label", muestraWifiyHora);
BLYNK_CONNECTED()
if (isFirstConnect)
Blynk.syncAll();
isFirstConnect = false;
WiFiManager wifi;
wifi.autoConnect("Alarma Cueva");
Blynk.config(auth, "lacueva2016.ddns.net");
//Blynk.begin(auth, ssid, pass);
pinMode(LED, OUTPUT);
digitalWrite(LED, HIGH);
rtc.begin();
Timer.setInterval(5000L, calculaRSSIyReloj);
Timer.setInterval(10000L, CheckConnectionProc);
Timer.run();
This is the response in serial
0‚~?–4û!ƒ“’…OCAZþû*WM:
*WM: AutoConnect
*WM: Connecting as wifi client…
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 3
*WM: IP Address:
*WM: 192.168.1.106
[3138]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
///_, /////_
/__/ v0.4.3 on Arduino
[3230] Free RAM: 41928
[3255] Cmd skipped:16
[5001] Connecting to lacueva2016.ddns.net:8442
[5055] <[02|00|01|00] 7147415706734becb602fac38b680ed4
[5065] >[00|00|01|00]È
[5065] Ready (ping: 4ms).
[5065] <[11|00|02|00]Gver[00]0.4.3[00]h-beat[00]10[00]buff-in[00]256[00]dev[00]Arduino[00]build[00]Apr 22 2017 22:55:29[00]
[5179] <[10|00|03|00|00]
[5196] >[00|00|02|00]È
[5217] >[14|00|03|00|06]
[5244] >vw[00]4[00]0
[5371] >[14|1E]b[00|04]
[5371] >vr[00]2
[6374] >[14|1E]b[00|04]
[6374] >vr[00]2
[7374] >[14|1E]b[00|04]
[7374] >vr[00]2
[8278] <[13|00|04|00]33[00]label[00] Señal: 52% Reloj: 00:00
After 13 minutes:
[778278] <[13|00] [00]33[00]label[00] Señal: 58% Reloj: 00:12
[778287] >[00|00] [00]È
[778385] >[14|1E]b[00|04]
[778385] >vr[00]2
[779367] >[14|1E]b[00|04]
[779367] >vr[00]2
[780367] >[14|1E]b[00|04]
[780367] >vr[00]2
[781367] >[14|1E]b[00|04]
[781367] >vr[00]2
[782369] >[14|1E]b[00|04]
[782369] >vr[00]2
[783278] <[13|00]¡[00]33[00]label[00] Señal: 58% Reloj: 00:13
Do you see something wrong?
Thanks in advance!
