hi, i try RTC example from " exemple RTC esp32 " but my arduino ide give me an error, or more.
i want esp32 works like a RTC and update date and time when it connected to server NTP .
thanks for help me
the code is this
http://twitter.com/blynk_app
Blynk can provide your device with time data, like an RTC.
Please note that the accuracy of this method is up to several seconds.
App project setup:
RTC widget (no pin required)
Value Display widget on V1
Value Display widget on V2
WARNING :
For this example you'll need Time keeping library:
https://github.com/PaulStoffregen/Time
This code is based on an example from the Time library:
https://github.com/PaulStoffregen/Time/blob/master/examples/TimeSerial/TimeSerial.ino
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "dda232c8fd3a48789e674cb780bea925";
char ssid[] = "ASUS";
char pass[] = "YourPassword";
WidgetRTC rtc;
// Digital clock display of the time
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
// Send time to the App
Blynk.virtualWrite(V1, currentTime);
// Send date to the App
Blynk.virtualWrite(V2, currentDate);
// Begin synchronizing time
rtc.begin();
// Other Time library functions can be used, like:
// timeStatus(), setSyncInterval(interval)...
// Read more: http://www.pjrc.com/teensy/td_libs_Time.html
// Display digital clock every 10 seconds
timer.setInterval(10000L, clockDisplay);
and arduino ide give me this
Arduino:1.8.9 (Windows 10), Scheda:"ESP32 Dev Module, Disabled, Default, QIO, 80MHz, 4MB (32Mb), 921600, None"
C:\Users\steti\Documents\Arduino\libraries\Time-master\DateStrings.cpp: In function 'char* monthStr(uint8_t)':
C:\Users\steti\Documents\Arduino\libraries\Time-master\DateStrings.cpp:76:66: error: 'strcpy_P' was not declared in this scope
strcpy_P(buffer, (PGM_P)pgm_read_word(&(monthNames_P[month])));
C:\Users\steti\Documents\Arduino\libraries\Time-master\DateStrings.cpp: In function 'char* dayStr(uint8_t)':
C:\Users\steti\Documents\Arduino\libraries\Time-master\DateStrings.cpp:90:61: error: 'strcpy_P' was not declared in this scope
strcpy_P(buffer, (PGM_P)pgm_read_word(&(dayNames_P[day])));
PiĂą di una libreria trovata per "WiFi.h"
Usata: C:\Users\steti\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0\libraries\WiFi
Non usata: C:\Users\steti\Documents\Arduino\libraries\WiFiNINA
Non usata: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
Errore durante la compilazione per la scheda ESP32 Dev Module.
