HI, Im trying to use the RTC widget, but it is not compiling, I’m using an Esp32 and my IDE version is 1.8.5…
is somebody having this problem too?
I fixed your topic category.
We can’t guess… or see over your shoulder
Please post (properly formatted) your code that displays the issue.
This is the code
#include <Ethernet.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
// Digital clock display of the time
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
// Send time to the App
Blynk.virtualWrite(V1, currentTime);
// Send date to the App
Blynk.virtualWrite(V2, currentDate);
Blynk.begin(auth);
// Begin synchronizing time
rtc.begin();
// Other Time library functions can be used, like:
// timeStatus(), setSyncInterval(interval)...
// Read more: http://www.pjrc.com/teensy/td_libs_Time.html
// Display digital clock every 10 seconds
timer.setInterval(10000L, clockDisplay);
'timer.run();
you have an ’ in front of this. That will generate an error
It doesnt work without too
Without an error log output this code isn’t much worth in this case
Please… more details… what is the EXACT error?
Arduino: 1.8.5 (Windows 10), Placa:"ESP32 Dev Module, Default, QIO, 80MHz, 4MB (32Mb), 921600, None"
E:\Documents\arduino-1.8.5\libraries\blynk-library-master\examples\Widgets\RTC\RTC.ino:44:21: fatal error: TimeLib.h: No such file or directory
compilation terminated.
exit status 1
Erro compilando para a placa ESP32 Dev Module
Este relatório teria mais informações com
"Mostrar a saida detalhada durante a compilação"
opção pode ser ativada em "Arquivo -> Preferências"
And this is a root cause. Do you have it installed? It should be visible in library manager if it is. How have you installed Blynk library, as normally TimeLib.h it is included in package?
It is not in library manager, how can i get it?
Then You have not installed full Blynk Library release, where it exists. Sure it can be installed manually/independently from library manager in Arduino Ide too, but I insist on installing full Blynk release package.
this might help: http://help.blynk.cc/getting-started-library-auth-token-code-examples/how-to-install-blynk-library-for-arduino
This confused me too at one point
The name of the library is actually “Time” not “TimeLib”. Make sure you have the latest library containing both Time.h & TimeLib.h
If you look inside Time.h you will find ONLY this:
#include "TimeLib.h"
But both are included in package for compatibility. That is why it is best to install all those from release.
It worked… I downloaded the full blynk library, thank you guys
Is there any problem on using RTC on esp32? cause on my is showing 1970
No issues that I am aware of… I use it in this and other projects on an ESP32
The 1970 basically means it is not yet synchronized with the “Internet” time.
Search this forum for 1970 and look at the various topics on this issue.
