RTC code to show value on widget
Can somebody give me a code to show Time in the rtc widget and use it in a project.
Have you look into basic RTC example?
I have. Just don’t know how to write the value to the widget or extract the values
Ok, for that I would recommend you to read this http://www.arduino.cc/en/Tutorial/StringAdditionOperator it may help.
virtualwrite for rtc?
Here you are:
//#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
#include <TimeLib.h>
#include <WidgetRTC.h>
int isFirstConnect = true;
char auth[] = "blablablablabla";
WidgetRTC rtc;
BLYNK_ATTACH_WIDGET(rtc, V5);
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
isFirstConnect = false;
  Blynk.begin(auth, "WIFI", "Password" ,IPAddress (xxx,xxx,x,xx));
    // Wait until connected
  // Begin synchronizing time
  rtc.begin();
  // Display digital clock every 10 seconds
  timer.setInterval(5000L, clockDisplay);
  timer.setInterval(5000L, clockvalue);
// Digital clock display of the time
void clockDisplay()
  // You can call hour(), minute(), ... at any time
  // Please see Time library examples for details
  BLYNK_LOG("Current time: %02d:%02d:%02d %02d %02d %d",
            hour(), minute(), second(),
            day(), month(), year());
void clockvalue()
 int gmthour = hour();
  if (gmthour == 24){
     gmthour = 0;
  String displayhour =   String(gmthour, DEC);
  int hourdigits = displayhour.length();
  if(hourdigits == 1){
    displayhour = "0" + displayhour;
  String displayminute = String(minute(), DEC);
  int minutedigits = displayminute.length();
  if(minutedigits == 1){
    displayminute = "0" + displayminute;
  String displaysecond = String(second(), DEC);
  int seconddigits = displaysecond.length();
  if(seconddigits == 1){
    displaysecond = "0" + displaysecond;
  String displaycurrenttime = displayhour + ":" + displayminute;
  Blynk.virtualWrite(0, displaycurrenttime);
The result:
Display at V0 and RTC widget at V5 (+02:00) (Spain)
Regards!
Thanks to @Costas and @Pavlo! They helped me a lot with this widget!!
Thanks a lot mate.
The setup was working fine yesterday but from today it’s showing the year 1970… I don’t know what’s wrong. Can you take a look ? @Pavlo @Dmitriy
Please post your code.
> > // These are the interrupt and control pins for СС3000
> > #define ADAFRUIT_CC3000_IRQ   3
> > #define ADAFRUIT_CC3000_VBAT  5
> > #define ADAFRUIT_CC3000_CS    10
> > #include <SPI.h>
> #include <Adafruit_CC3000.h>
> #include <BlynkSimpleCC3000.h>
> #include <SimpleTimer.h>
> SimpleTimer timer;
> // You should get Auth Token in the Blynk App.
> // Go to the Project Settings (nut icon).
> char auth[] = "41e3380ec436461c9bd7e3eeafb58d54";
> WidgetRTC rtc;
> void setup()
>   pinMode(13,OUTPUT);
>   Serial.begin(9600); // See the connection status in Serial Monitor
>    Blynk.begin(auth, "net_9718015549call", "macbeth123", WLAN_SEC_WPA2);
>   while (Blynk.connect() == false) {
>   rtc.begin();
> //Serial.print(hour());
>   timer.setInterval(10000L, clockDisplay);
> void clockDisplay()
> void clockvalue()
>   if (gmthour == 24){
>      gmthour = 0;
> void loop()
>   Blynk.run();
>   timer.run();
This is tarter strange, do you know if the problem happened after device restart, or was it online for the whole day?
After the restart.
I checked it yesterday, it was working fine.
Today I plugged it in and it started showing the year 1970 :confused:
@vshymanskyy could the problem be in
rtc.begin();
? Maybe it should be placed in BLYNK_CONNECTED?
Any updates? @Dmitriy @vshymanskyy
@KAUSTUBHAGARWAL could you please try my suggestion?
BLYNK_CONNECTED() {
    rtc.begin();
I don’t know the problem…It’s not working.
The weird thing is it was working fine on one day and now like this :confused:
I just checked rtc and working no problems… I think we need to look deeper in DEBUG logs…
I think rtc is on a 5 minute update cycle.
wait five minutes and your clock should update
@KAUSTUBHAGARWAL @Dmitriy @vshymanskyy
The RTC shows 1/1/1970 for the first 5 minutes if you miss this line of code:
while(Blynk.connect() == false);
equivalent to:
while(Blynk.connect() == false) { }
This line has to be inserted after Blynk.begin and before rtc.begin:
Blynk.begin(auth, wifi, ssid, pass);     // Blynk Server
rtc.begin();
In such a way the rtc hows immediately the correcet date and time.
Regarding the code to format date and time, in my opinion, the most elegant lines of code are:
sprintf(Date, "%04d/%02d/%02d", year(), month(), day());
Blynk.virtualWrite(V1, Date);
Blynk.virtualWrite(V2, Time);
If you don’t want leading zero, exclude the 0 from the formatting section of sprintf.
Ciao,
Giancarlo
Date and Time are arrays of char:
char Date[16];
char Time[16];
Thanks Gianca for sharing !!!
That did the trick
