Not the App version, what version is running on the RPI This OP said using C++, so probably WireingPi, but there is also a NodeJS and a Python version of Blynk Library for RPi. All are different, so your “Me Too” may have nothing to do with this OP issue.
@Pol We need a lot more details… RPi type, does it disconnect when using other sketches as well, actual type and version of library, Local or Cloud server (and if Local, is it running on same RPi)… etc… including seeing the actual code you are trying to run now. Please properly format your code after pasting it here:
Also, since the RPI is a full SOC not just a microconrtoller, there could be many issues at play not just your code or the library… is the Linux version all up to date? Is the RPi running on a good stable 5v power supply, or just USB off a PC or something. Any other background processes running… and so on.
