I’m a bit lost, I have the board Robotdyn Mega +WiFi R3 ATmega2560+ESP8266, and I can not even do the basics that would light the led 13 through the Blynk ios application.
I’ve seen these topics, but it was not much help WEMOS Mega +WiFi R3 ATmega2560+ESP8266
I also looked at these tests and worked perfectly all of them, testing the Arduino Mega 2560, ESP8266, and the two together. http://www.sysengineering.ru/blog/электроника-контроллер-arduino-mega-с-esp8266/
I have already put the Blynk example code of ESP8266_Standalone. Uploading to ESP only. (This Code)
char pass[] = "YourPassword";
And the result of the serial monitor was:
⸮EO⸮v⸮$rz⸮4C(r⸮[76] Connecting to Juninho
[3080] Connected to WiFi
[3080] IP: 192.168.0.24
[3080]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.2 on Arduino
[3150] Connecting to blynk-cloud.com:80
[8150] Connecting to blynk-cloud.com:80
[8419] Ready (ping: 133ms).
But as I’m kinda lost I do not know what code to put in the Arduino Mega because what I put:
#include <ESP8266_Lib.h>
#define EspSerial Serial3
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
// to avoid delay() function!
Modifying only the line #define EspSerial Serial1 to #define EspSerial Serial3 in the two options Serial1 or Serial3, the result is the same on the serial monitor:
[9]
___ __ __
/___/ v0.5.2 on Arduino Mega
[592] Connecting to Juninho
[1602] ESP is not responding
As I did not know what to try until I tried to update Firmware ESP8266, I do not know if this is related but every time I give the AT command I would receive this:
Ai-Thinker Technology Co. Ltd.
ready
AT
ERROR
AT+GMR
ERROR
Note: Even though I received this error in the AT command everything that was previously described is valid, because I have re-built all of these tests again to see if it gave the same result.
If anyone has any idea what I’m doing wrong or suggest some tuturial for me to follow. I appreciate it.
