Hi everyone
does anyone know how to use this widget?
Thank you
Best Regards
Hi everyone
Thank you
Best Regards
I’ve never used it before but if I understand correctly according to documentation it’s like the zeRGBa widget but with more settings like Button, Brightness and Animation Speed.
Hi
Where find the code?
Best regards
I’m so sorry, I couldn’t find any code for this widget.
It looks like the widget is simply a way of inputting values for RGB, Brightness, speed etc.
It’s up to you to use these in your sketch in whatever way you want to. Previously you would have had to use a combination of widgets to be able to input these values and now these can be controlled from a single widget.
Hi
I ask the blynk developers and who may know. is there an example like for the other widgets?
Thank you
