hi sorry for the delay.
here is an image of my app
and the code I am self taught so don’t know how good or structured it is so my apologies
if it not very good any criticism will be taken as a part of the learning curve
#include <Time.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <OneWire.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#define Relay_Pin D5//active board
#define LED_Pin D6//LED_Pin
OneWire ds(D7);//active board // on pin 10 (a 4.7K resistor is necessary)
//WidgetLED led1(V1);
WidgetRTC rtc;
BLYNK_CONNECTED() {
// Synchronize time on connection
Blynk.syncVirtual(V2,V4, V5, V6,V7,V8,V9);// restor slider values
Blynk.email("mymail@talktalk.net", "Subject: reset Tortoise Heater", "there as been a power cut you need to reset the sliders"); //send e-mail on restart
rtc.begin();
char ssid[] = "your ssid";
char password[] = "your password";
char auth[] = "your auth";//insid board
//char auth[] = "your auth";//outside board
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius;
float s1;
float s2;
float s3;
int adr;
int DayHighTemp;
int NightHighTemp;
int LowTemp;
int Days;
int Day_Hours;
int Day_Minutes;
int Day_Settings;
int Night_Hours;
int Night_Minutes;
int Night_Settngs;
int VirtualPin;
bool Am;
bool Reset = V3;
double temp;
bool power = 0;
* Relay Control *
* start *
* this is where I need the *
LowTemp value *
void relay_Control(){
if (Am == true){
if(s2 < LowTemp){
Blynk.setProperty(V11, "color","#FF0000");
Blynk.setProperty(VirtualPin, "color","#FF0000");
digitalWrite (Relay_Pin, HIGH);
digitalWrite (LED_Pin, HIGH);//LED_Pin on
else if (s2 > LowTemp){
Blynk.setProperty(V11, "color","#00FF00");
Blynk.setProperty(VirtualPin, "color","#00FF00");
digitalWrite (Relay_Pin, LOW);
digitalWrite (LED_Pin, LOW);//LED_Pin off
if (Am == false){
if(s2 < LowTemp){
* Relay Control *
* End *
* Look For Changes to the Sliders On the settings Tab *
* in the Blynk App *
* start *
BLYNK_WRITE(V3)
* this looks for the reset slider if reset slider is *
* moved ot position 1 then you can change the *
*Slider values *
Reset = param.asInt(); // if Reset slider is moved to ON then Reset = 1
if (Reset == 1){ // and the other sliders can be moved
Blynk.setProperty(V3, "color","#FF0000");
else {
Blynk.setProperty(V3, "color","#3700FD");
BLYNK_WRITE(V4){
if (Reset == 1){
Day_Hours = param.asInt(); // assigning incoming value from pin V4 to a variable
Blynk.virtualWrite(V4, Day_Hours);
BLYNK_WRITE(V5){
if (Reset == 1){
Day_Minutes = param.asInt(); // assigning incoming value from pin V5 to a variable
Blynk.virtualWrite(V5, Day_Minutes);
Blynk.setProperty(V5, "color","#23CBCF");
BLYNK_WRITE(V6){
if (Reset == 1){
Day_Settings = param.asInt(); // assigning incoming value from pin V6 to a variable
DayHighTemp = Day_Settings;
Blynk.virtualWrite(V6, Day_Settings);
Blynk.setProperty(V6, "color","#00FF00");
BLYNK_WRITE(V7){
if (Reset == 1){
Night_Hours = param.asInt(); // assigning incoming value from pin V7 to a variable
Blynk.virtualWrite(V7, Night_Hours);
BLYNK_WRITE(V8){
if (Reset == 1){
Night_Minutes = param.asInt(); // assigning incoming value from pin V8 to a variable
Blynk.virtualWrite(V8, Night_Minutes);
Blynk.setProperty(V8, "color","#23CBCF");
BLYNK_WRITE(V9){
if (Reset == 1){
Night_Settngs = param.asInt(); // assigning incoming value from pin V9 to a variable
NightHighTemp = Night_Settngs;
Blynk.virtualWrite(V9, Night_Settngs);
Blynk.setProperty(V9, "color","#00FF00");
* End *
* DS18B20 Sensor *
* Starts Here *
if ( !ds.search(addr)) {
ds.reset_search();
delay(250);
return;
for( i = 0; i < 8; i++) { //we need to drop 8 bytes of data
adr = (addr[7]);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) { // we need 9 bytes to drop off
data[i] = ds.read();
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
* DS18B20 Sensor *
* Ends Here *
* Heater Control *
* start *
*this is where LowTemp is sest *
celsius = (float)raw / 16.0;
if(adr == 228) { //inside board Other Side
//if(adr == 89) { //outside board Other Side
s1 = (celsius);
if(adr == 197) { //inside boade Heater Control
//if(adr == 96) { //out side board Heater Control
s2 = (celsius); //change celsius to fahrenheit if you prefer output in Fahrenheit;
Am = isAM();
if(Am == true){
if(Day_Hours == hour()){ //set LowTemp for the Night time setting
if (Day_Minutes >= minute() && Day_Minutes <= minute()){
LowTemp = DayHighTemp -1;
VirtualPin = V6;
if(Am == false){
if(Night_Hours == hour()){ //set LowTemp for the Night time setting
if(Night_Minutes >= minute()&& Night_Minutes <= minute()+5){
LowTemp = NightHighTemp -1;
VirtualPin = V9;
if(adr == 92) { //inside board Out Side
//if(adr == 116) { // outside board Out Side
s3 = (celsius);
relay_Control();//call relay_Control function
* Heater Control *
* End *
*this make sure the sliders move *
*Back to there original position if they *
*are accidentaly moved *
if(Am == true){
Blynk.virtualWrite(V1, "AM");
else if(Am == false){
Blynk.virtualWrite(V1, "PM");
Blynk.virtualWrite(V2, LowTemp +1);
Blynk.virtualWrite(V10, s1);
Blynk.virtualWrite(V11, s2);
Blynk.virtualWrite(V12, s3);
Blynk.setProperty(V13, "color","#00FF00");
Blynk.virtualWrite(V13, s2);
pinMode(Relay_Pin, OUTPUT);
pinMode(LED_Pin, OUTPUT);//digitalWrite (LED_Pin, LOW);//LED_Pin off
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
Blynk.begin(auth, ssid, password);// See the connection status in Serial Monitor
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH)
type = "sketch";
else // U_SPIFFS
type = "filesystem";
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
Serial.println(hour());
timer.setInterval(500, sendSensor);
ArduinoOTA.handle();
