Is there any way to control the GPIO pins with RESTASK app on raspberypie.
I would like to execute blynk buttons with NFC tags but dont know how to triger the GPIOs.
Ok. I managed to get it working. Pins numbers correspond to gpio numbers. But have another problem. The app triggers the gpio like switch. I would like to togle as a push button.
I don’t know how you are coding anything, so can’t say how… but yes, you could use a timeout timer to process the LOW command after X many milliseconds.
For this task i dint do any coding. I just set the RESTtask app and tasker to toggle the command. The commands are executed ok. I would like just a litle more time betwen them.
