REST API, how to appear online?
Hi all!
I am using Blynk through REST API (no library) and so far all is good. But I would like my device to appear online on the mobile APPs and the web console. I want this so I can notify my users on disconnect of device. (It will be on GPRS cellular network)
Is there a way to achieve this ?
Thanks,
Theodore
Would you like to check device state (online/offline), or something else ?
Yes, I would like to check the device’s state and use an automation to inform users. My problem is that my devices appear always offline. I don’t know of any way to change that through REST API.
I understand that through the library this is done as a housekeeping service or something, I don’t know for sure how. That’s why I am asking here, maybe someone has that experience already.
And it would be great if this could be done with minimum bytes transfered (something like a ping) because I am on GPRS data.
P.S. I tried pinging “blynk.cloud” server every some secs but to no avail…
I
No, not at the moment.
Currently, A device is online when it has an Always On connection with the server. Using the API doesn’t create an Always On connection.
Then, if I understand correctly, the heartbeat feature comes as secondary, doesn’t do anything without an always on connection. True?
BLYNK_HEARTBEAT specifies how frequently the device and server talk to each other across the Always On connection. It has no relevance as far as HTTP(S) API calls are concerned.
Ok, thanks!
