Resetting when WIFI comes back
I am a beginner in IOT and I wrote a small program that measures the electricity
consumption of my house and sends it to the remote application every second.
For this I use an arduino UNO R3 card which accesses the internet via WIFI and my box.
Everything works fine but here is my problem:
Every night I turn off the WIFI to turn it back on in the morning.
Sometimes too, due to various problems, he cuts himself during the day and comes back.
So I would like my code to regularly test the connection to Blynk and reset it if necessary.
How to do ?
Thanks for any help.
My code :
#include <WiFi.h>
#include <BlynkSimpleWifi.h>
char ssid[] = "XXXXXXX";      // your network SSID (name)
char pass[] = "XXXXXX";              // your network password
volatile int periode=0;
volatile int PuissanceInstantanee=0;
volatile int PuissanceInstantaneeDelta=0;
volatile int MemPuissanceInstantanee=0;
volatile int tempo=300;
volatile int TdernierFront=0;
volatile float CoutKwh=0.2228/1000;
volatile float DeltaP=0;
volatile float DeltaT=0;
volatile long NbFlash=0;
volatile long MemNbFlashDelta=0;
volatile int EtatBoutonDelta=0;
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
  // Set incoming value from pin V0 to a variable
  EtatBoutonDelta = param.asInt();
  if (EtatBoutonDelta==1)
    MemNbFlashDelta=NbFlash;
    Blynk.virtualWrite(V6, 0);
    MemPuissanceInstantanee=PuissanceInstantanee;
    DeltaT=millis();
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
  // Change Web Link Button message to "Congratulations!"
  Blynk.setProperty(V3, "offImageUrl", "********");
  Blynk.setProperty(V3, "onImageUrl",  "********");
  Blynk.setProperty(V3, "url", "********");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
  Blynk.virtualWrite(V5, PuissanceInstantanee);
  Blynk.virtualWrite(V2, CoutKwh*PuissanceInstantanee);
    if (PuissanceInstantaneeDelta>=0)
         Blynk.virtualWrite(V7, PuissanceInstantaneeDelta);
    Blynk.virtualWrite(V7, 0);
    Blynk.virtualWrite(V6, (NbFlash-MemNbFlashDelta)*CoutKwh);
    long TDeltaMilliseconde = (millis()-DeltaT);
    int TDeltaseconde = TDeltaMilliseconde/1000;
    int TDeltaMinute=TDeltaseconde/60;
    int TDeltaSeconde=TDeltaseconde-60*TDeltaMinute;
    Blynk.virtualWrite(V4,TDeltaMinute );
    Blynk.virtualWrite(V9,TDeltaSeconde );
  pinMode(2,INPUT);
  Serial.begin(9500);
  // init affichage
  Blynk.virtualWrite(V8,"---");
  attachInterrupt(digitalPinToInterrupt(2), rpm_fan2, FALLING);
  // to avoid delay() function!
void rpm_fan2()
  periode=millis()-TdernierFront;
  if (periode>tempo)
    PuissanceInstantanee=3600000/periode;
    PuissanceInstantaneeDelta=(PuissanceInstantanee-MemPuissanceInstantanee);
    TdernierFront=millis();
    NbFlash++;
@Falcon12 Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Ok, done.
No, you’ve put the triple backticks at the beginning of your post, not immediately before your code.
You’re right, sorry
This is from the examples - HandleDisconnect.ino
Does this point you in the right direction?
  ESP32, Arduino, Raspberry Pi and the likes over the Internet.
  You can easily build mobile and web interfaces for any
    Downloads, docs, tutorials: https://www.blynk.io
    Sketch generator:           https://examples.blynk.cc
    Blynk community:            https://community.blynk.cc
    Follow us:                  https://www.fb.com/blynkapp
                                https://twitter.com/blynk_app
  This example shows how to keep WiFi connection on ESP8266.
/* Fill in information from Blynk Device Info here */
//#define BLYNK_TEMPLATE_ID           "TMPxxxxxx"
//#define BLYNK_TEMPLATE_NAME         "Device"
//#define BLYNK_AUTH_TOKEN            "YourAuthToken"
char pass[] = "YourPassword";
int lastConnectionAttempt = millis();
int connectionDelay = 5000; // try to reconnect every 5 seconds
  // check WiFi connection:
  if (WiFi.status() != WL_CONNECTED)
    // (optional) "offline" part of code
    // check delay:
    if (millis() - lastConnectionAttempt >= connectionDelay)
      // attempt to connect to Wifi network:
      if (pass && strlen(pass))
        WiFi.begin((char*)ssid, (char*)pass);
        WiFi.begin((char*)ssid);
Thanck you microBrian, yes it seems to be able to help me, I will try to use it :slightly_smiling_face:
