Hi friends. is there any way to resetting Nodemcu WiFi credentials configuration with nodemcu flash button ?
is any example for this ?
thanks
thanks
Double Reset Detector was mentioned a few days ago, see https://github.com/datacute/DoubleResetDetector
thanks for reply. do you know how to define nodemcu flash button to this library ? maybe in DRD_ADDRESS ?
#include <DoubleResetDetector.h>
// Number of seconds after reset during which a
// subseqent reset will be considered a double reset.
#define DRD_TIMEOUT 10
// RTC Memory Address for the DoubleResetDetector to use
#define DRD_ADDRESS 0
DoubleResetDetector drd(DRD_TIMEOUT, DRD_ADDRESS);
pinMode(LED_BUILTIN, OUTPUT);
Serial.println();
Serial.println("DoubleResetDetector Example Program");
Serial.println("-----------------------------------");
if (drd.detectDoubleReset()) {
Serial.println("Double Reset Detected");
digitalWrite(LED_BUILTIN, LOW);
Serial.println("No Double Reset Detected");
digitalWrite(LED_BUILTIN, HIGH);
// Call the double reset detector loop method every so often,
// so that it can recognise when the timeout expires.
// You can also call drd.stop() when you wish to no longer
// consider the next reset as a double reset.
drd.loop();
DRD_ADDRESS is simply the storage address (0) in RTC memory area to check if a reset was done within the DRD_TIMEOUT duration. Doesn’t look like you need to define the reset button as a reset is any reset, hardware or software.
So I understand nodemcu or esp8266 DRD_ADDRESS is 0. how to adding the button in this library ? Can you guidance me ?
thanks
Does the sketch not work i.e. different LED states depending on interval between resets?
I dont understand it
I just adding this library to my sketch and not worked
#include <FS.h> //this needs to be first, or it all crashes and burns...
//#define BLYNK_DEBUG // Comment this out to disable debug and save space
#include "DHT.h"
#include <I2CSoilMoistureSensor.h>
#define DHTPIN 2 // The pin you connect to
#define DHTTYPE DHT11 // DHT 11 Change this if you have a DHT22
DHT dht(DHTPIN, DHTTYPE,16); // Change this to
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
int x = analogRead(A0);
char server[] = "192.168.1.104";
//for LED status
#include <Ticker.h>
Ticker ticker;
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
char blynk_token[34] = "";
bool shouldSaveConfig = false; //flag for saving data
void tick()
//toggle state
int state = digitalRead(BUILTIN_LED); // get the current state of GPIO1 pin
digitalWrite(BUILTIN_LED, !state); // set pin to the opposite state
void saveConfigCallback () { //callback notifying us of the need to save config
Serial.println("Should save config");
shouldSaveConfig = true;
ticker.attach(0.2, tick); // led toggle faster
Serial.println();
timer.setInterval(2000, sendDHT);
//set led pin as output
pinMode(BUILTIN_LED, OUTPUT);
// start ticker with 0.5 because we start in AP mode and try to connect
ticker.attach(0.6, tick);
//SPIFFS.format(); //clean FS, for testing
Serial.println("Mounting FS..."); //read configuration from FS json
if (SPIFFS.begin()) {
Serial.println("Mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("Reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("Opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(blynk_token, json["blynk_token"]);
Serial.println("Failed to load json config");
Serial.println("Failed to mount FS");
Serial.println();
//end read
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 33); // was 32 length
Serial.println(blynk_token);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
wifiManager.setSaveConfigCallback(saveConfigCallback); //set config save notify callback
//set static ip
// this is for connecting to Office router not GargoyleTest but it can be changed in AP mode at 192.168.4.1
//wifiManager.setSTAStaticIPConfig(IPAddress(192,168,10,111), IPAddress(192,168,10,90), IPAddress(255,255,255,0));
wifiManager.addParameter(&custom_blynk_token); //add all your parameters here
//wifiManager.resetSettings(); //reset settings - for testing
//set minimu quality of signal so it ignores AP's under that quality
//defaults to 8%
//wifiManager.setMinimumSignalQuality();
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep, in seconds
wifiManager.setTimeout(600); // 10 minutes to enter data and then Wemos resets to try again.
//fetches ssid and pass and tries to connect, if it does not connect it starts an access point with the specified name
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("LabkhandGiah", "12345678")) {
Serial.println("Failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
Serial.println("Motasel shod :)"); //if you get here you have connected to the WiFi
ticker.detach();
//turn LED off
digitalWrite(BUILTIN_LED, HIGH);
strcpy(blynk_token, custom_blynk_token.getValue()); //read updated parameters
if (shouldSaveConfig) { //save the custom parameters to FS
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("Failed to open config file for writing");
json.printTo(configFile);
configFile.close();
//end save
Serial.println("local ip");
Blynk.config(blynk_token, server);
Blynk.connect();
void sendDHT()
//Read the Temp and Humidity from DHT
float h = dht.readHumidity();
int hum = (int) h;
int tem = (int) t;
//Write values to V04 and V05
Blynk.virtualWrite(4, hum);
Blynk.virtualWrite(5, tem);
timer.setInterval(2000, moisture);
void moisture(){
int y = map(x, 600, 230, 0, 100);
if (y > 100)
y = 100;
Blynk.virtualWrite(V1, y);
drd.loop();
You shouldn’t add “none Blynk code” to a Blynk sketch until you have tested the code without Blynk.
Just work through the basic sketch from GitHub until it works for you.
Checked the library here with a WeMos and it works fine. Simple and effective.
worked with flash button or reset button ?
Ah sorry, the reset button as there is no flash button on a WeMos.
its worked without blynk code. I chekcked it with nodemcu by double tapping Reset button everything erased but I dont know how to add this to blynk code.
it erased your WiFi credentials?
WiFIManager uses SPIFFS to store parameters so RTC address 0 would have no effect on this.
I looked at your merged code and Arduino basics says you don’t duplicate entries into the merged sketch i.e. you have 2 Serial.begin(). Just keep the proper ESP rate of 115200.
The GitHub is just a basic example which you have to expand upon. Do you know the process of clearing parameters with WiFiManager?
