Arduino Nano, iOs, BLE-HM10
I have been trying to figure out how to reset a Blynk slider switch to zero when a segmented switch is pressed. This is a controller for an RC car. I have a 3 button segmented switch to change direction and stop. There is a slider switch to change the motor speed. On the press of the switch, any button, I want to set the motor speed to zero and set the slider to zero. At this point my code sets the motor speed to zero but it does not change the slider. I have searched endlessly for a solution, I think I am following the examples appropriately but I can’t get it to work. Any ideas?
void setup(){
startBLYNK_LCD();
pwm.begin();
pwm.setPWMFreq(FREQUENCY); //Set PWM frequency of PC8695 to 50Hz for the Servo
pinMode(PWM, OUTPUT); //Set Pin 9 to Output
pinMode(DIR, OUTPUT); //Set Pin 6 to Output
pinMode(winchDIR1, OUTPUT); //Set Pin 10 to Output
pinMode(winchDIR2, OUTPUT); //Set Pin 11 to Output
pinMode (A0, INPUT); //Set voltage read pin A0 to input
void loop(){
sendBatteryVoltage();
/**************** V1 BLYNK Read JOYSTICK position and adjust steering Servo Position***********/
BLYNK_WRITE(V1) {
int joystick_Pos, pulse_Width;
int x_position = param[0].asInt(); //uses joystick x position for steering left/right
int y_position = param[1].asInt(); //not used
joystick_Pos = map(x_position, 0, 255, SERVOMIN, SERVOMAX); //map joystick Blynk values to servo values
pulse_Width = int(float(joystick_Pos)/1000000 * FREQUENCY * 4096);//calculates incremental steering value between 0-180
pwm.setPWM(pca9685_Pin, 0, pulse_Width); //PCA9685 Channel#(pins),PWM On, PWM Off) 0=left, 90=straight, 180=right
/**************** END V1 BLYNK Read JOYSTICK position and adjust steering Servo Position***********/
/********** V6 Read Blynk SLIDER SWITCH and Convert to MOTOR SPEED Variables**********/
BLYNK_WRITE(V6) {
motorSpeed = param.asInt(); // assigning incoming value from pin V6 to a variable for Motor Speed (0-255)
// this value is used in the stateMachine function
if (switchState == 1){
analogWrite(PWM, motorSpeed); // Send PWM signal to motor
digitalWrite(DIR, HIGH);
else if (switchState == 2){
analogWrite(PWM, 0); // Send PWM signal to motor
digitalWrite(DIR, LOW);
else if (switchState == 3){
Serial.print("V6 Slider value is: ");
Serial.println(motorSpeed);
/********** END V6 Read Blynk SLIDER SWITCH and Convert to MOTOR SPEED Variables**********/
/************* V7 BLYNK THREE SEGMENT SWITCH Vehicle Direction *************/
BLYNK_WRITE(V7) {
switchState = (param.asInt()); // Get Switch state value 1 = Forward, 2 = Neutral, 3= Reverseswitch (switchState){ //From BLYNK_WRITE(V3) switchState = 1, 2 or 3 on Blynk App
Blynk.virtualWrite(V6, 0);
switch (switchState) {
case 1: // FORWARD
//Blynk.syncVirtual(V6);
break;
case 2: // NEUTRAL
analogWrite(PWM, neutral); // Set motor speed to 0
Blynk.setProperty(V6, "color", "#D3435C");
break;
case 3: // REVERSE
break;
/*************END V7 BLYNK THREE SEGMENT SWITCH Vehicle Direction*************/
