I have a simple test sketch what send every second a value between 0 - 100 to V(0)
i use reports widget on the android phone.
so i have one data streem virtual pin V(0)
On the phone i have a value display what shows the new value every second ,
so the server received the info right.
when it sends the report it seems the granularity is only ones a minute.
Why is the resolution not in seconds ?
Thanks , Christiaan
attached arduino one code with esp8266 and exel results
“ Superchart supports currently 2 types of granularity:
Minute granularity - 1h , 6h , 1d ;
Hour granularity - 1w , 1m , 3m ;
This means that minimum chart update interval is 1 minute for 1h , 6h , 1d periods. 1 hour for 1w , 1m and 3m periods. As Blynk Cloud is free to use we have a limit on how many data you can store. At the moment Blynk Cloud accepts 1 message per minute per pin. In case you send your data more frequently your values will be averaged. For example, in case you send value 10 at 12:12:05 and than again 12 at 12:12:45 as result in chart you’ll see value 11 for 12:12.”
I saw in the discription that when you choose 1 minute granularity it saves 24 * 60 * 60 results in a day
but this is then only on a local server not on the blynk cloud server as i understood.
I need a saving time for every 10 seconds (ones a second is not nessesary) Is there a change that you improve Blynk cloud server to 10 seconds granularity
I recall references to using a RAW data setting in Local Server for finer granularity, but not sure if that is applicable for the new Reports Widget or only the SuperChart CSV option. I don’t use either, so @ArduinoFan would have to search the forum for more details.
