So its already 24 hr since the last report and it still say error when i try to generate a new report. I see another post about this but no response and solution so i made this post
i need the report but there is no responses in my post and other post about this problem, its already 3 days since the last report but it still said that ‘Reports limit reached. One device can send only 10 reports per day’
The bug is confirmed. Working on it. Thanks for the report.
hey I’m facing the same issue
when I tried to download the report it is showing “Reports limit reached. One device can send only 10 reports per day”
please help me.
i could not download important test reports
Hello, @sachinmc. It is correct. Report download limit per device 10 times per day for all plans.
You can read
Max number of **Export Data** calls (
/external/api/data/get ) per device per day (both UI and HTTPS API export): 10
https://docs.blynk.io/en/blynk.console/limits#https-api-limits
