tomixps
                    January 21, 2018, 12:09pm
              1
              Hello. what code to the remote control button. I would like to remotely control another board from the phone. For example, if I press the button, the relay switches on another wemos. I need a code.
I found such a thing but I do not know how to apply it in the code.
http://blynk-cloud.com/auth_token/get/pin
                Costas
                    January 21, 2018,  1:12pm
              2
              how to use it in the code?
                Costas
                    January 21, 2018,  2:52pm
              4
              With the super powerful Webhook widget.
              Can you send me a code? Thanks in advance
                Costas
                    January 24, 2018,  4:48pm
              6
Keep studying this until you can make it work in a web browser, then repeat for Webhook widget,
              How to control the relay via http (push button)?
I used it but it does not work.
https://blynkapi.docs.apiary.io/#
                Costas
                    January 30, 2018,  5:13pm
              8
              Paste the dozens of url’s you tried in a browser and the actual GPIO numbers you want to control.
Presumably you are using Blynk’s cloud server.
                Costas
                    January 30, 2018,  5:41pm
              10
Which GPIO pin is the relay connected to and do you know the difference between a GPIO number and the labels printed on the ESP development boards?
What message do you see in the browser with the url you are using?
Most relays are active LOW, should you be sending a 0 to switch the relay ON?
              @tomixps  please stop demanding others to write code for you. It is against forum rules (and you may get banned soon).
                tomixps
                    February 3, 2018,  2:35pm
              12
              blynk-cloud.com  works for me only I would like it to be a push and not a switch
http://blynk-cloud.com/XXXXXXXXXXXX/get/D14
                Gunner
                    February 3, 2018,  3:19pm
              14
 tomixps:
Ok I did not know
You clearly haven’t been following my reign of terror
