Hi, with the help of this comunnity i made my first relay switch wifi. But there is a problem, when internet is down, there is no way to turn on and off the relay, even without the physical button. Is there a way to make this work?
used: Nodemcu wemos d1 mini, 4 relay module, hilink 5v dc
#include <ESP8266mDNS.h> // For OTA with ESP8266
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
void checkPhysicalButton();
int relay1State = LOW;
int pushButton1State = HIGH;
int relay2State = LOW;
int pushButton2State = HIGH;
int relay3State = LOW;
int pushButton3State = HIGH;
int relay4State = LOW;
int pushButton4State = HIGH;
#define AUTH "JfDhJD1ZrrJX2rc3965gdMjwpV59tvUj"
#define WIFI_SSID "Fibertel WiFi737 2.4GHz"
#define WIFI_PASS "0142336387"
#define SERVER "blynk-cloud.com " // Comment-out if use Blynk hosted cloud service
#define PORT 8442
#define RELAY_PIN_1 12 //D6
#define RELAY_PIN_2 16 //D0
#define RELAY_PIN_3 4 //D2
#define RELAY_PIN_4 5 //D1
#define PUSH_BUTTON_1 2 //D4
#define PUSH_BUTTON_2 14 //D5
#define PUSH_BUTTON_3 13 //D7
#define PUSH_BUTTON_4 1 //TX
#define VPIN_BUTTON_1 V12
#define VPIN_BUTTON_2 V13
#define VPIN_BUTTON_3 V14
#define VPIN_BUTTON_4 V15
#define OTA_HOSTNAME "Home_Automation"
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
Blynk.syncVirtual(VPIN_BUTTON_3);
Blynk.syncVirtual(VPIN_BUTTON_4);
// Alternatively, you could override server state using:
// Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
// Blynk.virtualWrite(VPIN_BUTTON_2, relay2State);
// Blynk.virtualWrite(VPIN_BUTTON_3, relay3State);
// Blynk.virtualWrite(VPIN_BUTTON_4, relay4State);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
relay1State = param.asInt();
digitalWrite(RELAY_PIN_1, relay1State);
BLYNK_WRITE(VPIN_BUTTON_2) {
relay2State = param.asInt();
digitalWrite(RELAY_PIN_2, relay2State);
BLYNK_WRITE(VPIN_BUTTON_3) {
relay3State = param.asInt();
digitalWrite(RELAY_PIN_3, relay3State);
BLYNK_WRITE(VPIN_BUTTON_4) {
relay4State = param.asInt();
digitalWrite(RELAY_PIN_4, relay4State);
if (digitalRead(PUSH_BUTTON_1) == LOW) {
// pushButton1State is used to avoid sequential toggles
if (pushButton1State != LOW) {
// Toggle Relay state
relay1State = !relay1State;
// Update Button Widget
pushButton1State = LOW;
if (digitalRead(PUSH_BUTTON_2) == LOW) {
// pushButton2State is used to avoid sequential toggles
if (pushButton2State != LOW) {
relay2State = !relay2State;
pushButton2State = LOW;
if (digitalRead(PUSH_BUTTON_3) == LOW) {
// pushButton3State is used to avoid sequential toggles
if (pushButton3State != LOW) {
relay3State = !relay3State;
pushButton3State = LOW;
if (digitalRead(PUSH_BUTTON_4) == LOW) {
// pushButton4State is used to avoid sequential toggles
if (pushButton4State != LOW) {
relay4State = !relay4State;
pushButton4State = LOW;
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS,"blynk-cloud.com", 8442);
ArduinoOTA.setHostname(OTA_HOSTNAME); // For OTA - Use your own device identifying name
ArduinoOTA.begin(); // For OTA
pinMode(RELAY_PIN_1, OUTPUT);
pinMode(PUSH_BUTTON_1, INPUT_PULLUP);
pinMode(RELAY_PIN_2, OUTPUT);
pinMode(PUSH_BUTTON_2, INPUT_PULLUP);
pinMode(RELAY_PIN_3, OUTPUT);
pinMode(PUSH_BUTTON_3, INPUT_PULLUP);
pinMode(RELAY_PIN_4, OUTPUT);
pinMode(PUSH_BUTTON_4, INPUT_PULLUP);
// Setup a function to be called every 100 ms
timer.setInterval(500L, checkPhysicalButton);
ArduinoOTA.handle(); // For OTA
