#define BLYNK_TEMPLATE_ID "TMPLHYty_y66"
#define BLYNK_DEVICE_NAME "Home Automation"
#define BLYNK_AUTH_TOKEN "TR4GHJjb6fXPkgPSeeLU2c1q7s8nlorR"
#include <NTPClient.h>
#include <Espalexa.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include "Wifi.h"
#include "ota.h"
//char ssid[] = "Access With Permission_2.4GhZ";
//char pass[] = "Tank9555";
//OUTPUT
#define OUT1 16 //D0
#define OUT2 5 //D1
#define OUT3 4 //D2
#define OUT4 0 //D3
//INPUT
#define SWITCH1 2 //D4
#define SWITCH2 14 //D5
#define SWITCH3 12 //D6
#define SWITCH4 13 //D7
bool R1FLAG = 0;
bool R2FLAG = 0;
bool R3FLAG = 0;
bool R4FLAG = 0;
bool R5FLAG = 0;
bool S1FLAG = 1;
bool S2FLAG = 1;
bool S3FLAG = 1;
bool S4FLAG = 1;
String Device_1_Name = "Light";
String Device_2_Name = "Fan";
String Device_3_Name = "Night Lamp";
String Device_4_Name = "Socket";
void LightChanged(uint8_t brightness);
void FanChanged(uint8_t brightness);
void NightLampChanged(uint8_t brightness);
void SocketChanged(uint8_t brightness);
Espalexa espalexa;
WiFiUDP ntpUDP;
String dayofWeek[] = {"Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"};
NTPClient timeClient(ntpUDP, "pool.ntp.org",19800);
BLYNK_WRITE(V0) {
R1FLAG = param.asInt();
digitalWrite(OUT1,!R1FLAG);
EspalexaDevice* d1 = espalexa.getDevice(0);
if (R1FLAG == 1) {
d1->setPercent(100);
d1->setPercent(0);
BLYNK_WRITE(V1) {
R2FLAG = param.asInt();
digitalWrite(OUT2,!R2FLAG);
EspalexaDevice* d2 = espalexa.getDevice(1);
if (R2FLAG == 1) {
d2->setPercent(100);
d2->setPercent(0);
BLYNK_WRITE(V2) {
R3FLAG = param.asInt();
digitalWrite(OUT3,!R3FLAG);
EspalexaDevice* d3 = espalexa.getDevice(2);
if (R3FLAG == 1) {
d3->setPercent(100);
d3->setPercent(0);
BLYNK_WRITE(V3) {
R4FLAG = param.asInt();
digitalWrite(OUT4,!R4FLAG);
EspalexaDevice* d4 = espalexa.getDevice(3);
if (R4FLAG == 1) {
d4->setPercent(100);
d4->setPercent(0);
BLYNK_WRITE(V4) {
//R5FLAG = param.asInt();
digitalWrite(OUT1,HIGH);
digitalWrite(OUT2,HIGH);
digitalWrite(OUT3,HIGH);
digitalWrite(OUT4,HIGH);
Blynk.virtualWrite(V0, LOW);
Blynk.virtualWrite(V1, LOW);
Blynk.virtualWrite(V2, LOW);
Blynk.virtualWrite(V3, LOW);
BLYNK_WRITE(V5) {
digitalWrite(OUT1,LOW);
digitalWrite(OUT2,LOW);
digitalWrite(OUT3,LOW);
digitalWrite(OUT4,LOW);
Blynk.virtualWrite(V0, HIGH);
Blynk.virtualWrite(V1, HIGH);
Blynk.virtualWrite(V2, HIGH);
Blynk.virtualWrite(V3, HIGH);
void checkPhysicalButton()
//FOR SWITCH 1
if (digitalRead(SWITCH1) == LOW && S1FLAG == 0) {
digitalWrite(OUT1, LOW);
R1FLAG = 1;
S1FLAG = 1;
if (digitalRead(SWITCH1) == HIGH && S1FLAG == 1) {
digitalWrite(OUT1, HIGH);
d1->setPercent(0);
R1FLAG = 0;
S1FLAG = 0;
//FOR SWITCH 2
if (digitalRead(SWITCH2) == LOW && S2FLAG == 0) {
digitalWrite(OUT2, LOW);
R2FLAG = 1;
S2FLAG = 1;
if (digitalRead(SWITCH2) == HIGH && S2FLAG == 1) {
digitalWrite(OUT2, HIGH);
d2->setPercent(0);
R2FLAG = 0;
S2FLAG = 0;
//FOR SWITCH 3
if (digitalRead(SWITCH3) == LOW && S3FLAG == 0) {
digitalWrite(OUT3, LOW);
R3FLAG = 1;
S3FLAG = 1;
if (digitalRead(SWITCH3) == HIGH && S3FLAG == 1) {
digitalWrite(OUT3, HIGH);
d3->setPercent(0);
R3FLAG = 0;
S3FLAG = 0;
//FOR SWITCH 4
if (digitalRead(SWITCH4) == LOW && S4FLAG == 0) {
digitalWrite(OUT4, LOW);
R4FLAG = 1;
S4FLAG = 1;
if (digitalRead(SWITCH4) == HIGH && S4FLAG == 1) {
digitalWrite(OUT4, HIGH);
d4->setPercent(0);
R4FLAG = 0;
S4FLAG = 0;
if (brightness == 255) {
Blynk.virtualWrite(V0,HIGH);
Blynk.virtualWrite(V0,LOW);
Blynk.virtualWrite(V1,HIGH);
Blynk.virtualWrite(V1,LOW);
Blynk.virtualWrite(V2,HIGH);
Blynk.virtualWrite(V2,LOW);
Blynk.virtualWrite(V3,HIGH);
Blynk.virtualWrite(V3,LOW);
void checkBlynkStatus() { // called every 3 seconds by SimpleTimer
if (WiFi.status() == WL_CONNECTED) {
int b1 = Blynk.connected();
if (b1 == 0) {
Serial.println("Blynk not connected");
Blynk.virtualWrite(V8,"Internet Not Connected");
Blynk.config(auth);
Blynk.connect();
else {
Blynk.virtualWrite(V8,"Internet Connected");
else {
WiFi.setAutoReconnect(true);
WiFi.persistent(true);
Serial.println("Reconnecting");
void timeupd() {
if (WiFi.status() == WL_CONNECTED){
timeClient.update();
Blynk.virtualWrite(V6,timeClient.getFormattedDate());
int day = timeClient.getDay();
Blynk.virtualWrite(V7,dayofWeek[day]);
void setup () {
Serial.println("insetup");
readwifi();
//Blynk.begin(auth,ssid,pass);
timer.setInterval(3000L, checkBlynkStatus);
ota();
pinMode(OUT1, OUTPUT);
pinMode(OUT2, OUTPUT);
pinMode(OUT3, OUTPUT);
pinMode(OUT4, OUTPUT);
pinMode(LED_BUILTIN,OUTPUT);
pinMode(SWITCH1, INPUT_PULLUP);
pinMode(SWITCH2, INPUT_PULLUP);
pinMode(SWITCH3, INPUT_PULLUP);
pinMode(SWITCH4, INPUT_PULLUP);
digitalWrite(OUT1, !R1FLAG);
digitalWrite(OUT2, !R2FLAG);
digitalWrite(OUT3, !R3FLAG);
digitalWrite(OUT4, !R4FLAG);
Serial.println("Setting up");
Serial.println("inespalexa");
espalexa.addDevice(Device_1_Name, LightChanged); //simplest definition, default state off
espalexa.addDevice(Device_2_Name, FanChanged);
espalexa.addDevice(Device_3_Name, NightLampChanged);
espalexa.addDevice(Device_4_Name, SocketChanged);
espalexa.begin();
timeClient.begin();
timer.setInterval(1000L, timeupd);
ArduinoOTA.handle();
espalexa.loop();
checkPhysicalButton();
When i upload this code to my ESP8266 and run it using usb power supply the code works fine. But when i power it through my 5v Adapter (SMPS power supply) and held the physical input pins by my hands the relay chatters . Even if i touch the insulation wires the relay chatters.
