Refresh After Sending App. To Background
Cannot find setting on iPhone app. to set how long fetching occurs after sending it to the background. When running the same app. on android, it stops immediately after sending it to background.
Note: I’m running on a local server with latest apps & server .jar file.
According to this article, it should halt immediately. Did not find anything stating a difference between iPhone and Android…
To replicate:
  1. setup app to connect with server
  2. add BLYNK_READ on a virtual channel
  3. set the refresh time to 1-5 secs
  4. inside blynk_read, send message to terminal on pc (shows request from app)
  5. send app. to background and monitor the terminal
You will see the iPhone continues requesting for 3 minutes and the Android halts immediately.
BLYNK_READ(V0) // Value Field On Iphone App
	Blynk.virtualWrite(V30, String(millis()));
Can you post the whole sketch?
This came from a simple sketch which can easily be created with your own security, auth, etc. In addition, you will need to create a new project on your phones (iphone and android).
Regards
I’m a bit too lazy for that :wink: I was asking because I don’t really understand the problem. Doesn’t the data show up in the serial monitor when app is not “active”?
Do you mean Terminal in App or Serial Monitor in IDE?
Maybe iPhones have a 3 minute “timeout”.
As previously stated, the article written by Pavel states “Blynk app can “ask” your hardware for the data when the app is open. When Blynk app is closed or is running in background, data is not requested.”.My assumption was the iPhone would act the same as the Android. I would like to cut down on cellular data traffic as it costs $.
As for your question on Terminal or Serial Monitor, the Serial.println(“sending data”); would be to the Serial Monitor inside IDE. Its a way to see if the phone application is still requesting data after being put into the background.
No it’s not. Your MCU will run forever sending data to Serial Monitor.
If the app is still running in the background then widgets with a refresh frequency of 1 to 5 seconds should continue to work.
I would paste a very basic sketch so the dev’s can test with Android and iPhone.
BLYNK_READ(Virtual_chan) “ONLY” gets fired on Hardware side when the “TIME” set for refresh has expired. If the phone app. is “OPEN”, this process will continue at that rate. Once the phone app. is closed or sent to background (hit home button on iPhone), its suppose to stop making those refresh requests. Works as advertised on Android, not so much for iPhone.
Does this need to be filed as a bug? Is there another setting I’m not aware of that determines how long the fetches occur as being sent to background.
Also include your app settings.
I think there is confusion over what “background” means. To me it means the app is still running and maybe iPhone and Android have a different idea of what it is.
Background on either platform would be when you open the blynk phone application (make sure its running) then hit the home button and then say open your email, calendar, etc.
To STOP, KILL, HALT the program depends on the phone (iPhone/Android).
  1. Android-> open SETTINGS->Apps->Blynk->Force Stop
  2. iPhone-> quickly press HOME twice. Scroll(left/right) to blynk application and swipe it vertical.
As I have stated, please read article by Pavel. I didn’t write it, just am reading what was said. This article never differentiated iphone vs android.
@minnkid I never use PULL so I had to check what @Pavlo had written about it.
@Pavlo can you please explain the following:
Blynk app can “ask” your hardware for the data when the app is open. When Blynk app is closed or is running in background, data is not requested.” because Android and iPhone seem to be handling it differently.
I think this is it: Introduction - Blynk Documentation
@Pavlo the quote is taken from http://help.blynk.cc/getting-started-library-auth-token-code-examples/blynk-basics/how-to-display-any-sensor-data-in-blynk-app
OP states it takes 3 minutes for data to stop flowing on iPhone when the app is in the background whereas it’s immediate with Android.
@Eugene?
At the moment, Blynk_read is not triggered by server if there is no open network connection with the app.
When transferring app from active to background, iOS app holdes its network connection for some “special” short time to finish queued requests and to be ready if user gets back shortly. The exact time is defined by iOS system and depends on available resources, battery, whether “low power mode” is on, etc., etc.
BTW, there are cases when network connection is not closed even the app is in background (both on iOS and Android). E.g. if you have a GPS widget set to work in background.
Please consider to not depend on Blynk_read not being called when there are no open applications. The initial goal of such limitation was to save processing resources on our servers - AFAIK this limitation may be removed in the future.
Maybe we need to introduce a new command which app should send on transitioning to background, but I believe this is a low priority, @Dmytro ?
Yeap. Not a priority right now. However, I believe we will fix it very soon.
I also afraid after enabling this some hardware may die :smile:.
Dmitriy,
Just a thought on possible implementation. Can the phone app. pass along a call to a function just like it does for BLYNK_READ(). Example: when the phone app. is sent to the background, call a new function like BLYNK_PHONESTAT(param=phone status)…Note: could be used to pass other phone status as well.
One could then capture the param if desired or ignore it entirely by not including the function in their sketch. So, if the status param was BACKGROUND, the hardware can set a flag to STOP updating virtual channels to cut down on traffic. It saves cell costs and decreases server loads. This also would not break any ones hardware since it is passive in nature.
Regards
Why just not push the data from the device on APP_CONNECTED call :thinking:
I’ve tried that but it has MANY issues based on:
  1. phone platform (iPhone/Android)
  2. if your app. is running as shared OR out of actual account
Too many permutations to list. For example:
Android:
  1. If application was previously left in RUNNING state:
    -Fires BLYNK_APP_CONNECTED & BLYNK_APP_DISCONNECTED when brought to foreground then background…Good :grinning:
    -Fires BLYNK_APP_CONNECTED when brought to foreground BUT if you stop app. then switch to background, the BLYNK_APP_DISCONNECTED is never called. On the harware side, I would be stuck sending updates forever. :disappointed_relieved:
  2. If app. was not left running and then app. brought to foreground and RUN button pressed, you never get BLYNK_APP_CONNECTED. On the harware side, I would never start sending updates. :disappointed_relieved:
The iPhone is similar but has its own unique anomalies.
As you can see from above, the hardware would definitely get confused and break. This is pretty simple to duplicate on your end to see what I’m talking about (using your example code).
Summary,
That is why I was thinking about a different function to simply update Foreground/Background status. Per Eugene’s comment, I’m wondering if the existing functions are tied to network connection status. This would also explain differences between phone platforms. The other issues with Shared Access ?:thinking:
