On your latest update I see that you offer hardware support for the Red Bear Lab Blend Micro and CC3200 micro-controller but I was wondering if you are going to offer hardware support for more Red Bear Lab micro-controllers particularly the Red Bear Lab Blend micro-controller. http://redbearlab.com/blend/
Just use the same example as for Blend Micro…
Can you point me in the right direction when you mean by just using the same example as the Blend Micro. Do you mean the code and if so where is that listed. Thanks
that listed. Thanks
Just use the latest library and it’s located in examples folder as usual… https://github.com/blynkkk/blynk-library/tree/master/examples/Boards_BLE/RedBearLab_BlendMicro
