Reconnecting to server after defined time
Hi all! I have an idea to reduce traffic consumption of Blynk. In this case I decided to create a timer, that will disconnect blynk from blynk server for some time. After that, it has to connect Blynk again.
My hardware is: Arduino UNO with GSM shield SIM900 by keyestudio.
The issue is: This sleeping code works uncorrectly and I has no idea, why (Maybe, there is a reason to use setTimeout unstead of setInterval? But, as I understand it is not the “key” of the problem). And Second question: How is better to configure button V7 (switch or push).
Need your help.
#include "ACS712.h"
#include "MQ7.h"
#define TINY_GSM_MODEM_SIM900
#define pinBOOT 9  // нога BOOT или K на модеме M590, на SIM900 это 9
                     //8 нога НЕ РАБОТАЕТ, НЕ ВКЛЮЧАТЬ В ПРОГРАММУ
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
#include <DHT.h>
int timer_sensor = 0;
int timer_reconnect = 0;
int timer_CO = 0;
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
// Ваш токен
char auth[] = "31a0c84a8c23xxxxxxxxxxxxxxxxxxxxxx";
char apn[]  = "internet";
char user[] = "";
char pass[] = "";
void reconnectBlynk() {       //?WAKE UP METHOD!
  if (!Blynk.connected()) {
    Serial.println("Lost connection");
    if(Blynk.connect()) {
      Blynk.notify("Connected to internet!");
      timer.disable(timer_reconnect); //disable current timer
      delay(100);
    else {
      Serial.println("Not reconnected");
BLYNK_WRITE(V9){         //THIS IS NEEDED FOR READING SLIDER, THAT SENDS TIME OF SLEEP (FROM 1 TO 300)
  int sleep = param.asInt();     //SLEEP - VARIABLE FOR HOLDING THIS TIME OF SLEEP
  delay(100);
  Blynk.virtualWrite(V8, sleep);
  //SET UP SLEEP TIMER (AFTER TIME, IT CALLS METHOD reconnectBlynk (SEE ABOVE))
  timer_reconnect = timer.setInterval(sleep * 3600000L, reconnectBlynk);   //3600000L-HOUR, 1000L - 1 SECOND
  Serial.println(sleep);
  delay(100);
BLYNK_WRITE(V7) /////////SLEEP WHEN V7 IS ON!
  if (param.asInt())
       delay(100);
       Blynk.notify("Disconnected!");
       delay(100);
       Blynk.disconnect();
       delay(100);
       timer.disable(timer_sensor);
       delay(100);
       timer.enable(timer_reconnect); //ENABLE RECONNECT TIMER
       delay(100);
  //GSM SHIELD ON
  pinMode(pinBOOT, OUTPUT);
  digitalWrite(pinBOOT, HIGH);
  digitalWrite(pinBOOT, LOW);
  // Set GSM module baud rate (вставьте свою скорость)
  SerialAT.begin(9600);
  delay(3000);
  modem.restart();
  if(Blynk.connected()){
    Blynk.notify("Connected!");
    delay(3000);
Maybe try this (may or may not fix issue). And I would set V7 as switch, and have the code reset it back to 0/off when it connects.
       Blynk.connect();
    if(Blynk.connected()) {
     Blynk.virtualWrite(V7, 0); //reset switch
      //delay(1000); do not use delays
      //delay(100);
    else {
 if (Blynk.connected()) {  // If connected run as normal
Also as @Gunner has pointed out “Another glitch in SimpleTimer (of which BlynkTimer is based) is that when using timer ID labels, needed to do things like disable, enable, delete, etc. timers, it seems like the first timer in your code will also get ‘deleted’… I found making a simple “Sacrificial Timer” solves that little issue :slight_smile:”
so try adding this to your setup.
// "Sacrificial" Timer - needed when deleting timers as that will kill first timer created...
  timer.setTimeout(10L, []() {
  });  // END sacrificial Function
Thanks, I will try it!
