Probably better ways of doing it but what about a read and send in the setup?
can you please explain more to me? , thanks!
Experiment with the following
pinMode(sensorPin, INPUT);
Delay(10);
sendSensor();
is this correct if i want to receive only 1 notification?, i only need 1 notification when it needs to be watered and 1 when it’s watered.
char auth[] = "********************************************";
char ssid[] = "************************";
char pass[] = "******************************";
const int sensorPin = A0;
int sensorState = 0;
int lastState = 0;
sensorState = analogRead(sensorPin);
sensorState = map(sensorState, 0, 1023, 0, 100);
Blynk.virtualWrite(A0, sensorState);
if (sensorState >= 50 && lastState == 0) {
Serial.println("needs water, send notification");
Blynk.notify("Water your plants");
lastState = 1;
else if (sensorState <= 50 && lastState == 1) {
Blynk.notify("Plants Watered");
lastState = 0;
delay(1000);
First of all, you should read this:
You’ll see that the code that reads your sensor and sends the notifications should be in a function of its own, called at an appropriate frequency by a timer. Personally, I wouldn’t have thought that this needed to be any more frequently than once every hour.
Secondly, your ‘if’ statements overlap on the 50 reading, so you would get two notifications.
Personally, I’d probably leave a small gap between the sensor value tests in the ‘if’ statements, so that I don’t get multiple readings if the results fluctuate around the 50 mark. Maybe a <49 plus a >51 set of tests.
Ok I miss understood your intention. Try adding another condition to toggle your “sent notification” flag.
#include <SPI.h>;
#include <SimpleTimer.h>;
#include <ESP8266WiFi.h>;
#include <BlynkSimpleEsp8266.h>;
char auth[] = "**********************************************";
char ssid[] = "**********************";
char pass[] = "*****************************";
int lastState = 0;
int lastStateWet = 0;
void sendSensor(){
Serial.println(sensorState);
lastState = 1; //toggles message sent state
lastStateWet = 0; //toggles message sent stateWET
Blynk.notify("Water your plants”);
else if (sensorState <= 48 && lastStateWet == 0)
lastState = 0;
lastStateWet = 1;
Blynk.notify(“Plants were watered”);
Does this work like you expect? This is supposing your senor gives a bigger number when dry.
Thanks for answering Pete, this link was really useful; if i made a function that reads the sensor and sends the notification, then i added timer.setInterval(1000L, sendSensor);
, but this will call the function every 1 sec, so i will get the notification every 1 sec right? but as you said, 1 hour would be good, but if i called the function every 1 hour, the data in this hour will not be displayed or it will stay as it is when 1st read before going to a delay of 1 hour, right?
Yes, if you don’t use a flag to indicate that a notification has already been sent.
Set the flag to false when your board boots, then to true when an alert has been sent.
Clear the flag (set it to false) when the temperature dops/rises into the ‘acceptable’ temperature range.
i have a gauge on Blynk that displays the soil moisture data, so for example if the data was 55, then it went for a 1 hour delay, the data will stay 55, right?, because the board is in a delay now, but i want to keep everything working meanwhile sending notification every hour, can this happen?
It’s possible, but I don’t see th point in sending a notification every hour, 24 hours per day.
In my opinion, notifications should be use to alert the user to exceptional situations. If you want to know what the mosistuer level is every hour then look at the gauge in the app!
exactly, you’re right, sending a notification every 24 hours is better, so i have to set the time interval to 24 hours or what?, what should be changed in code to get this 24 hour notification, any tip please?, thanks in advance
I still don’t think a notification every 24 hours is the best approach. An email summary might be a better approach.
If you want to do something every 24 hours then the RTC widget is the tool that I’d use.
The point is that i don’t want to get spammed by notifications, i just want a delay between each notification, for example sending notification to water plants each hour just for a reminder if he forgot to water his plants.
so coding wise, timer.setinterval
will solve this?
Yes, you could do that, maybe with a button to cancel the alert if you remember to water the plants.
Maybe an automatic plant watered would be a better project?
i want to work 1st with notifications, the next thing is that i want to automatically do it, but for now, i just don’t want to get spammed with notifications, just need like 1 hour or anything between each notification, how can i do it?
In that case I’d just have a standard timer that runs every 60 minutes. Presumably the function that it calls will take some moisture readings and only send an alert if the readings are out of the acceptable range, otherwise you could simply use the timer function on the code without any need for Blynk.
as suggested before from @daveblynk, the code below is fine?:
#include <SPI.h>;
int lastState = 0;
void sendSensor(){
lastState = 0;
lastStateWet = 1;
I guess the question is, does the code do what you want.
yes, i just want to have delays between each notification, just don’t want to get spammed with notifications, but as the same time keep the data updated each 1 sec
Then you need two timers, one every second (seems a bit over the top to me) that takes the readings and updates Blynk, then one every hour that applies whatever logic test you think you need, then sends a notification if appropriate.
Pete,
