I guess the question is, does the code do what you want.
yes, i just want to have delays between each notification, just don’t want to get spammed with notifications, but as the same time keep the data updated each 1 sec
Then you need two timers, one every second (seems a bit over the top to me) that takes the readings and updates Blynk, then one every hour that applies whatever logic test you think you need, then sends a notification if appropriate.
Pete,
so i will have 2 functions, one for reading sensor that will be called in the setup every 1 sec, and the other is pushing notifications that will be called in the setup every 1 hour, right?
Correct.
so the code would look like that:
#include <SPI.h>;
#include <SimpleTimer.h>;
#include <ESP8266WiFi.h>;
#include <BlynkSimpleEsp8266.h>;
char auth[] = "********************************";
char ssid[] = "***************";
char pass[] = "***********************************";
const int sensorPin = A0;
int sensorState = 0;
void sendSensor(){
sensorState = analogRead(sensorPin);
sensorState = map(sensorState, 0, 1023, 0, 100);
Serial.println(sensorState);
Blynk.virtualWrite(A0, sensorState);
void notification(){
if (sensorState >= 51) { //send notification
Blynk.notify("Water your plants");
else if (sensorState <= 49) {
Serial.println("Does not need water");
pinMode(sensorPin, INPUT);
timer.setInterval(1000L, sendSensor); // to run sendSensor every 1 sec
timer.setInterval(600000L, notification); // to run notification every 10 minutes
right?
This serves no purpose, except to cause Blynk disconnections.
Otherwise it looks okay at a quick glance. How does it work in practice?
yeah you’re right, i am trying it now, thanks for the fast replies, much appreciated
it’s working just fine, but i am waiting 10 minutes at first, then after 10 minutes i will receive a notification, but i want to receive at 1st second a notification then receive every 10 minutes, what should i add to do so?
Add notification();
as the last thing in your void loop to call it immediately, once every time your device is booted.
i added it, but i am getting spammed by notifications
I think he miss typed. Add it to the end of your void setup()
, not the loop()
didn’t work
Doh!
That’ll teach me to answer forum questions while watching TV
probably because it takes 1 second to get the sensor valve. I would add an analog read to the notification function .
int sensorState1 = analogRead(sensorPin);
Serial.println("10 min Sensor Value");
Serial.println(sensorState1);
sensorState1 = map(sensorState1, 0, 1023, 0, 100);
Serial.println("10 min Sensor Value after Mapping");
if (sensorState1 >= 51) { //send notification
Serial.println("Water your plants");
else if (sensorState1 <= 49) {
//Blynk.notify("Does not need water");
the 1st second notification is still not working
are the serial prints showing up in the serial monitor?
yeah every 1 sec
try again with the edits. see if it is showing the 10 Minute values.
there is no 10 minutes value, i just want to receive a notification if the plants need to be watered every 10 mins for example, but i want to get it at 1st second, then initiate timer
